b20 vtec valvetrain noise
I recently put new type r LMA's in my stock b16a head because they were bad. Now the motor makes a clicking sound, but everything went back together the same way I took it off. The valve adjustment I used was for a gsr and type r, out of the hanes manual .007 intake, .008 exhaust. Any ideas? Do you need to run different clearances on a b20 vtec? I'm also running 11.5:1 pistons.This same noise is why i replaced the LMA's in the first place. Thanks for any help...
what do you mean by prime them? I spun the motor (no plugs) to get oil pres. before I started it . And its a constant ticking 2400-3700rpm's then the motor is too loud too hear, but I think it probably still makes the noise. The motor run fine though, but clicks????
he means soak the lma's in oil. just adjust the valves like a b16 -.7,.8 int, i dont remember off the top of my head but if you adjust them perfect and that dont fix it then change the lma's
I did soak them in oil for about a day and a half. The new LMA's only have 300 miles on them, and its been making the sound since start up. The LMA's were brand new from honda.
It might be piston slap, but I don't know what would cause it. It came out of nowhere, and yes 8 honda LMA's were not cheep.. Still confused.
I dident change the cam timing or anything like that???
well.. i do .006 intake and .007 exhaust. Then once I am done I turn the motor over twice and double check alot of times it changes a few thousands and I have to re adjust them and check again. I suggest you check the clearances again
jdm_sir2
22
Aug 31, 2009 08:30 PM
hbboostman
Jun 11, 2007 04:03 PM
bossman032
Feb 28, 2005 05:20 PM
