turn signal problem....
ok, so my drivers front turnsignal fell out going down the highway the other night. ever since then, my right side turn signals stopped working all togeather, they are just constantly on. i was expecting my left side to blink fast, which is does, but i wasnt expecting it to affect my right side?!?!?!
help, do i have to look for a crossed wire or somthing? or could it just be a fuse?
Both of your turn signals are on the same circut as each other. You need to look inside your fender at the wiring for your turn signal. If i remeber corretly there should be both a ground and harness plug pretty close to you turn signal it's self, if you do not see any thing phyiscally wronge with their fallow the wires. It sound to be that the pos of your harness is picking up current from some where Also is you inerior dash lights effect by this at all they two are on the same circut.
murderSI
Aug 13, 2013 04:38 PM
09metcalf.dylan
Nov 10, 2008 02:41 PM
pgpunkguy
Dec 24, 2005 04:29 AM
folta2169
Apr 11, 2005 10:40 AM
