something in the combustion chamber
Old Oct 21, 2006 | 01:48 PM
janz3n's Avatar
Default something in the combustion chamber
ok i was taking the spark plugs out of my dohc zc engine to get a piece of plastic out of the tube that broke off from the spark plug wires. well the piece fell in to the combustion chamber. its pretty tiny but i wanted to know if i tried to start up the engine with that piece in there would i hurt anything? or do i have to take the head off and get it out?
thanks
Old Oct 21, 2006 | 06:38 PM
lightcrx's Avatar
just turn the motor over without the spark pulgs and it should fly out
Old Oct 21, 2006 | 07:52 PM
JLefevers's Avatar
Default Re: (lightcrx)
i dont think it would hurt ne thing but it would not hurt to take the head off and replace the head gasket too juss in case bc u never know man bc if u do turn the motor over and it ***** sumthin up that sux
Old Oct 21, 2006 | 09:32 PM
Bob_760's Avatar
Default Re: (JLefevers)
a piece of plastic should be soft enough not to hurt anything but i'd personally try to vacuum it out, if you know how big it is try to find a hose thats small enough to fit into the plug hole and big enough to fit the piece into it then tape the hose onto a shop vac or vacuum then suck it out... alot less work than a headgasket job
Old Oct 22, 2006 | 12:18 AM
B16-CRX's Avatar
haha i dropped a piece of plastic down an intake by accident at work and just crossed my fingers and it flew out while driving. I used a borescope to make sure there was no damage.
Old Oct 22, 2006 | 12:03 PM
janz3n's Avatar
Default Re: (B16-CRX)
thanks for the reply's.. and not saying im an idiot..haha. id rather not do a headgasket job. just thought a piece of plastic would get jammed in a valve or something. i looked down into the tube and i couldnt see it.
Old Oct 22, 2006 | 12:52 PM
KURUPTinc's Avatar
Default Re: (janz3n)
if its a small peice it will burn off either in the combustion chamber or
it will burn off in the cat, if you have one. i dont know why people say it will come
out the exhaust when it will actually get stuck in the catalyst, like i said if you have one or else it will come out the exhaust.
Old Oct 22, 2006 | 06:04 PM
janz3n's Avatar
Default Re: something in the combustion chamber (janz3n)
ok just to let you know how big this piece is, id have to say its about 1/2 -1/4 inch square. kinda curved. part of the spark plug wire end that goes down the tube.
so you dont think this will get stuck in a vlave or something? id hate for the valve to get stuck open and hit the piston.
Old Oct 22, 2006 | 06:36 PM
UfoTofU's Avatar
I'd try a stick (chopstick, straw, etc.) with double sided sticky tape on the end. .5 x .25 inches is a pretty large chunk.
Old Oct 22, 2006 | 06:58 PM
janz3n's Avatar
Default Re: something in the combustion chamber (UfoTofU)
i meant its like 1/4 inch sqaured. and its kinda thin.
Old Oct 22, 2006 | 07:21 PM
CRXperiment's Avatar
Exact same thing happened to me and it was ok. I just drove it off. The temperatures of the combustion chamber will burn it off, or it will just get pushed out into your cat then burn.
Old Oct 22, 2006 | 07:24 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob_760 &raquo;</TD></TR><TR><TD CLASS="quote">a piece of plastic should be soft enough not to hurt anything but i'd personally try to vacuum it out, if you know how big it is try to find a hose thats small enough to fit into the plug hole and big enough to fit the piece into it then tape the hose onto a shop vac or vacuum then suck it out... alot less work than a headgasket job </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UfoTofU &raquo;</TD></TR><TR><TD CLASS="quote">I'd try a stick (chopstick, straw, etc.) with double sided sticky tape on the end. .5 x .25 inches is a pretty large chunk.</TD></TR></TABLE>
driving it out of there is the stupidest idea you could ever act upon, you are correct when you think it might fuc-k up a valve or such. get it out BEFORE you start your car. be smart. not S-M-R-T like the other homer simpsons in here.
Old Oct 22, 2006 | 07:30 PM
janz3n's Avatar
Default Re: something in the combustion chamber (SIred91)
haha.. well im going to try and get it out before i start the car. im liking the vacuum idea and the stick with double sided tape idea.. the only problem is i cant see the piece in there.
Old Oct 22, 2006 | 07:33 PM
SIred91's Avatar
Rainman
Get ta fishin'!
Old Oct 22, 2006 | 08:18 PM
project midnight's Avatar
my guess is that if it's plastic it won't hurt anything and it won't fly out the exhaust because it will get burned the hell up as soon as you start the car.
Old Oct 23, 2006 | 06:53 PM
KURUPTinc's Avatar
Default Re: something in the combustion chamber (moops vs moors)
you guys are forgetting how hot them combustion process is and it will burn off, as a landrover tech i pretty much have seen everything go down there and you should only be worried if you drop something metal. but if in doubt go for it dissasemble the top end while at it new belt and water pump wouldnt hurt.
Old Oct 23, 2006 | 07:05 PM
janz3n's Avatar
Default Re: something in the combustion chamber (KURUPTinc)
im going to replace the belt and pump but id rather not take the head off.. to much work for just a small piece of plastic.. im goign to try these methods to try and get it out.. im sure something will work but if nothign works i'll just start it up with it in there.
Fatdicklegend
Feb 15, 2015 04:40 PM
Cuong-nutz
33
Jul 24, 2014 08:56 PM
GSR_hatch936
Oct 23, 2008 09:36 AM
Elrusodan
Oct 4, 2007 02:52 PM
ddd4114
12
Jun 12, 2006 07:16 PM
