abs noise
I have a 92 gsr and my ABS pump keeps making that pressurizing noise while I drive. Does anyone else have a similar problem with ABS. Its F*&^ing annoying! Help please.
Most likely one of the valves is leaking the high pressure fluid to the reservoir and the pump is running to replenish it. Is the reservoir level changing as the car sits while running?
I only here the pump while i'm driving. a week ago I only head it after I apply the brake(after I release the brake), now its getting worse. The car brakes fine but Noisy when driving. Embarrassing...
I had both of the rear calipers replaced two weeks ago but the noise was there prior to the work but just worse. I took off the Fuse to the ABS and the noise stopped but really would want my ABS working. Could it be air in my Sytem? Help please...
