coilover height question
hey guys just wondering what height u had your coilovers on. i currently have my front lower and the back little higher. i have the front on like 6 and the rear a couple threads higher. just wanting to even it out some. about a 1 finger gap in rear and hardly any in front. running ground control coilovers btw
thanks
thanks
i already have washers in the back for the rear camber about 2 washers on each bolt i got go with 3 on each bolt, i a camber kit on the front.
anyone have some pics?
When you adjust ride height, toe-in changes and will wear out tires like no tomorrow if not aligned. That will happen ANY time you adjust ride height. Camber kit or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">When you adjust ride height, toe-in changes and will wear out tires like no tomorrow if not aligned. That will happen ANY time you adjust ride height. Camber kit or not.</TD></TR></TABLE>
i know i'm just wanna to fix this before i go get alignment
just look at these threads, plenty of pics to be seen, no need to post more here.
https://honda-tech.com/zerothread/1341591
https://honda-tech.com/zerothread?id=1466363
PrittyPearllude
Suspension & Brakes
Apr 11, 2006 06:50 PM
