coilover height question
Old Oct 21, 2006 | 02:10 AM
TURBODC4TEG's Avatar
Default coilover height question
hey guys just wondering what height u had your coilovers on. i currently have my front lower and the back little higher. i have the front on like 6 and the rear a couple threads higher. just wanting to even it out some. about a 1 finger gap in rear and hardly any in front. running ground control coilovers btw
thanks
Old Oct 21, 2006 | 06:54 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: coilover height question (TURBODC4TEG)
put it wherever you like, and then get the car aligned because it will need it (toe adjusted back to factory specs).
Old Oct 21, 2006 | 08:29 AM
Default Re: coilover height question (PatrickGSR94)
i already have washers in the back for the rear camber about 2 washers on each bolt i got go with 3 on each bolt, i a camber kit on the front.
anyone have some pics?
Old Oct 21, 2006 | 08:40 AM
Community Builder
When you adjust ride height, toe-in changes and will wear out tires like no tomorrow if not aligned. That will happen ANY time you adjust ride height. Camber kit or not.
Old Oct 21, 2006 | 11:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">When you adjust ride height, toe-in changes and will wear out tires like no tomorrow if not aligned. That will happen ANY time you adjust ride height. Camber kit or not.</TD></TR></TABLE>
i know i'm just wanna to fix this before i go get alignment
Old Oct 21, 2006 | 04:38 PM
Old Oct 21, 2006 | 08:13 PM
Community Builder
just look at these threads, plenty of pics to be seen, no need to post more here.
https://honda-tech.com/zerothread/1341591
https://honda-tech.com/zerothread?id=1466363
PrittyPearllude
Suspension & Brakes
Apr 11, 2006 06:50 PM
tekkynikality
Mar 6, 2004 09:23 AM
billyzakkus
Nov 28, 2003 12:07 PM
Nader_D
Jul 3, 2003 08:44 PM
Chip398193
Jul 29, 2001 11:19 AM
