Allignment Question
Allignment Question
I'm planning on getting coilovers, but im confused about one thing. SHould i just set the coilovers on where i plan to have them permanently , and then go and get it al;ligned at that height? And does that mean if i lower it or raise it more it would then be out of allignment?
Re: Allignment Question (Chip398193)
Yes. If you change the height of the spring perches, it will change the alignment of your camber and toe. Get the ride height where you want it, then have a four wheel alignment done for toe front and rear. Unless you have camber kits, you won't be able to adjust the camber settings. (i'm assuming this is for a civic) Hope this helps.
jg
jg
jromulo
11-10-2009 10:22 PM
