ECU Codes for EM1
Old Oct 20, 2006 | 09:44 PM
ArthurBrazil's Avatar
Default ECU Codes for EM1
Is there a way to get the codes out of an 99Si? I read the faq but that doesnt work on obdII i guess. Any suggestions appreciated.
Old Oct 20, 2006 | 10:00 PM
nighttrain33's Avatar
Default Re: ECU Codes for EM1 (ArthurBrazil)
Autozone will do it for free.
-Shane
Old Oct 20, 2006 | 10:02 PM
Really sweet.
Old Oct 20, 2006 | 10:08 PM
Default Re: (ArthurBrazil)
Honestly, I don't know of a DIY way to get codes out of an OBD2 vehicle. Autozone did check codes on my Sierra (99) when I threw a few. Of course the codes went away and I haven't thrown any since. It's ok since it saved me about $400.
-Shane
Old Oct 21, 2006 | 01:55 AM
20CiViCSi00's Avatar
Default Re: (nighttrain33)
^^^But if the codes are over what they can read (as they did with my Vtec selenoid malfunction(P1259)....) they will advise you to go to a Local Honda Dealership to get it diagnosed......DGAF
Old Oct 21, 2006 | 04:28 AM
Mr Hammond's Avatar
a/k/a Jomo
Funny story. We had a customer come in here from Autozone that told her the code they pulled was for the air fuel mixture not correct and she needed a new Mass Air Flow sensor for her 2002 Civic EX. So at least ask to see a print out or the actual code and match it up and don't listen to anything they say.
Oh and it ended up being a P0135 Primary Heated Oxygen Sensor Heater Circuit Malfunction. New O2 sensor and good as new.
Old Oct 21, 2006 | 08:01 AM
bsixteen's Avatar
kick panel passenger side. pull out the female plug and trip it w/ a paper clip or some ****. turn the key to light up the accessory's and **** and count the # of times it blinks just like in the FAQ
Old Oct 21, 2006 | 10:06 AM
Targa250R's Avatar
be professional
Default Re: ECU Codes for EM1 (Mr Hammond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Hammond &raquo;</TD></TR><TR><TD CLASS="quote">Funny story. We had a customer come in here from Autozone that told her the code they pulled was for the air fuel mixture not correct and she needed a new Mass Air Flow sensor for her 2002 Civic EX.</TD></TR></TABLE>
That's a classic. So have you been selling a lot of those Honda MAF sensors?
Old Oct 21, 2006 | 10:12 AM
Eran's Avatar
HT White Ops
Default Re: ECU Codes for EM1 (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">That's a classic. So have you been selling a lot of those Honda MAF sensors? </TD></TR></TABLE>
They're right next to the glow plugs for a d16y5.
Old Oct 21, 2006 | 10:15 AM
Default Re: (bsixteen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bsixteen &raquo;</TD></TR><TR><TD CLASS="quote">kick panel passenger side. pull out the female plug and trip it w/ a paper clip or some ****. turn the key to light up the accessory's and **** and count the # of times it blinks just like in the FAQ</TD></TR></TABLE>
That's for eg's. You have an EM1, how do you pull codes?
-Shane
Old Oct 21, 2006 | 11:09 AM
Mr Hammond's Avatar
a/k/a Jomo
Oh yeah I see them fail all the time. The parts department can't keep them on the shelf.
Old Oct 21, 2006 | 11:44 AM
Heylookits shawn's Avatar
its the same way for obd1.
i own an em1, to pull the code just take off the passenger side kick panel, there should be a blue or green plug, and you just stick a broken paperclip in the shape of a U in the two pins
Old Oct 21, 2006 | 01:12 PM
ishootpewpew's Avatar
Default Re: ECU Codes for EM1 (Heylookits shawn)
this is a nub question
what does pull the codes mean?
i want to know cuz i own an em1
Old Oct 21, 2006 | 01:17 PM
Targa250R's Avatar
be professional
Default Re: ECU Codes for EM1 (ishootpewpew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ishootpewpew &raquo;</TD></TR><TR><TD CLASS="quote">this is a nub question
When the Check Engine light (CEL) illuminates, the computer (electronic control unit, ECU) records one or more error codes describing the cause of the CEL. "Pulling the codes" refers to the process of checking which error codes are recorded in the ECU.
Old Oct 21, 2006 | 01:21 PM
ahhh icic
learn something new every day
so by asking for the codes, then there is something wrong with the engine, or it needs to be checked out correct?
Old Oct 21, 2006 | 02:22 PM
cambopheonix56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">That's for eg's. You have an EM1, how do you pull codes?
-Shane</TD></TR></TABLE>
It works
Old Oct 21, 2006 | 09:12 PM
Default Re: (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">
It works </TD></TR></TABLE>
You mean, the same applies for EM1's, correct?
-Shane
Old Oct 21, 2006 | 10:52 PM
Cool thanks for all the help. Ill try this tommorw and tell you all how it goes.
Old Oct 25, 2006 | 04:12 PM
bsixteen's Avatar
yep. i effed up at the track, launched shitty and wheel hopped like mad. limped the car to the end and my CEL was blinking. called up my friend to find out what the code was. stupid sparkplug wire came off the dissy! it was the only run i had that night cause i was scared to break ****
wantjoule
Honda Civic (2001 - 2005)
Jun 11, 2007 05:09 PM
Real Ek4
Dec 11, 2006 04:17 PM
hifi_civic
Jul 18, 2005 01:26 AM
BoRiCuA
Nov 30, 2004 01:23 PM
ZCHF
Jun 15, 2003 09:47 AM
