honda 4 wire o2 sensors the same?
Old Oct 20, 2006 | 09:31 PM
7808's Avatar
Default honda 4 wire o2 sensors the same?
i have a secondary o2 sensor from a 96 civic lx, can i use it in a 94 civic ex manifold?
obd 1 only has one, is the secondary o2 in a obdII civic any differnt from the o2 sensor in a obd1 civic? they both look the same, have the same plug, and wires
Old Oct 20, 2006 | 09:34 PM
hatchi's Avatar
Default Re: honda 4 wire o2 sensors the same? (7808)
my friend is using a primary o2 on his 2ndary spot and works fine
Old Oct 20, 2006 | 11:03 PM
1point7db2's Avatar
Default Re: honda 4 wire o2 sensors the same? (hatchi)
its same sensor just make sure wiring is long enough,all the second one does is measure the difference in a/f ratio-pretty much tells you whether the cat is working or not
Old Oct 21, 2006 | 07:14 AM
EJgsr's Avatar
Default Re: honda 4 wire o2 sensors the same? (1point7DA)
no there not the same some have male plugs and some have female... i might have to do a little sodering.
Old Oct 22, 2006 | 06:36 AM
speedracervroom's Avatar
as i was wondering the same thing F22 O2 sensor work on a del sol D16z6?
Old Oct 22, 2006 | 08:31 AM
F20Cteg's Avatar
Default Re: honda 4 wire o2 sensors the same? (USDMej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 &raquo;</TD></TR><TR><TD CLASS="quote">no there not the same some have male plugs and some have female... i might have to do a little sodering.</TD></TR></TABLE>
BINGO
DAP97SI
Jan 21, 2008 06:39 AM
King V
Nov 30, 2007 04:40 AM
98exturd
10
Aug 16, 2007 01:06 PM
AL ASPIRATED
Nov 11, 2003 10:34 PM
boostinb18
Jul 26, 2002 01:31 PM
