question about shifting into reverse?
Old Oct 20, 2006 | 06:38 PM
lamboextreme's Avatar
Default question about shifting into reverse?
i have a 00 si and most of the time is hard to shift into reverse. most of the time if i depress the clutch put it in neutral and press the clutch again and put it in reverse again it will go in kind of smooth. i was wondering what could be the problem or is this a common problem. the car has less than 60k mi. and it also has a racing clutch. thanks.
Old Oct 20, 2006 | 06:41 PM
Miracle's Avatar
Default Re: question about shifting into reverse? (lamboextreme)
You must have missed the 92-2000 forum. Click here.
Old Oct 20, 2006 | 06:49 PM
Default Re: question about shifting into reverse? (.Red.EM2)
i accidentally clicked here instead of the other section how can i transfer it to the other one?
Old Oct 20, 2006 | 06:51 PM
Miracle's Avatar
PM George Knighton... he can move it for you.
Old Oct 22, 2006 | 07:55 PM
Eran's Avatar
HT White Ops
Shift into 2nd gear, and then into reverse. Stops the synchros
Old Oct 22, 2006 | 07:56 PM
clm's Avatar
clm
The four Hondas I've owned have had the same issue. Putting it in first gear and then in neutral might help.
Old Oct 22, 2006 | 08:06 PM
cambopheonix56's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Shift into 2nd gear, and then into reverse. Stops the synchros </TD></TR></TABLE>
Old Oct 22, 2006 | 09:12 PM
Default Re: (cambopheonix56)
alright i'm going to try that, thanks.
Old Oct 22, 2006 | 09:20 PM
EK k kay's Avatar
Default Re: (lamboextreme)
Yup just hold the clutch down, shift into another gear, then shift into reverse normally. Sometimes if it doesn't work you can do this: shift into reverse and if it feels like it's not all the way in, release the clutch slowly and it should slide right in.
DC5_lov3r
Dec 10, 2007 05:51 PM
ablack934doorcivic
Nov 1, 2005 02:02 PM
eMbrace
May 14, 2005 07:47 AM
deeweezy
Mar 17, 2004 08:17 PM
canadaitr
Mar 24, 2003 07:17 PM
