question about shifting into reverse?
i have a 00 si and most of the time is hard to shift into reverse. most of the time if i depress the clutch put it in neutral and press the clutch again and put it in reverse again it will go in kind of smooth. i was wondering what could be the problem or is this a common problem. the car has less than 60k mi. and it also has a racing clutch. thanks.
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Shift into 2nd gear, and then into reverse. Stops the synchros </TD></TR></TABLE>
Re: (lamboextreme)
Yup just hold the clutch down, shift into another gear, then shift into reverse normally. Sometimes if it doesn't work you can do this: shift into reverse and if it feels like it's not all the way in, release the clutch slowly and it should slide right in.
DC5_lov3r
12-10-2007 05:51 PM
ablack934doorcivic
11-01-2005 02:02 PM
canadaitr
03-24-2003 07:17 PM
