seal on hardline question i need answered quick
Old Oct 20, 2006 | 05:16 PM
EG2Driver's Avatar
Default seal on hardline question i need answered quick
can i use hondabond to seal the hardline going into the slave cylinder? What else can i use it is leaking. Thanks
Old Oct 20, 2006 | 05:45 PM
Colt Seavers's Avatar
Default Re: seal on hardline question i need answered quick (DeadEnd9009)
It wouldn't realy work to well because of the fact that the part moves in and out. Your best bet is to just go and buy a new one... Their not that expensive.
Old Oct 20, 2006 | 05:48 PM
Luserkid's Avatar
Default Re: seal on hardline question i need answered quick (Colt Seavers)
You could try teflon, but it should make its own seal, could it be stripped threads or maybe you havent put the hardline down enough?
Old Oct 20, 2006 | 05:49 PM
EG2Driver's Avatar
Default Re: seal on hardline question i need answered quick (Luserkid)
no no its just the hardline that goes into the slave, not the actual piston that moves in and out. I got a new one and its leaking, thats why im asking.
Thanks guys!!
Old Oct 20, 2006 | 05:55 PM
stock_honda_coupe's Avatar
Take the line off, and look at both ends carefully. make sure they are round and have no nicks or scratches on them. If they are good, then puy them together and make sure they meet up straight and that you tighten it down well enough. be careful though, they strip easily.
BigMac28
Engine Machining & Assembly
Jan 23, 2019 06:17 AM
t0p_sh0tta
May 22, 2007 07:32 PM
BoostedEgHatchFl
Honda Motorcycles
Nov 5, 2005 11:49 AM
b16 matt
Apr 18, 2005 05:37 PM
