p54 or P72 A/C Bracket with SOHC Compressor what belt size(searched)
I cant seem to find the right size belt for a b16a2 using a P54 A/C Bracket with a SOHC compressor any run into this before if so what's the lenght, I just bought a 99Si Belt and its about 3 inches too long anyone please help Yes i did the Search
Re: p54 or P72 A/C Bracket with SOHC Compressor what belt size(searched) (xpwex)
I think I used the stock (99ex) belt on mine but I'm not 100%. Del-sol vtec belt should also work...
Im pretty sure I used the Del Sol belt. It barely fit but it did fit. If that doesnt work try the 94-97 integra belt.
Re: p54 or P72 A/C Bracket with SOHC Compressor what belt size(searched) (1 sLoW hAtCh)
I tried using the Integra one and the Del Sol but there both the same due to it having a bigger pulley on the compressor .....here the solution a B-Series motor has a 33" belt and when your using a B-series bracket for A/C and a SOHC compressor you have to use a 31" or 32" belt ...... thanks again....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 sLoW hAtCh »</TD></TR><TR><TD CLASS="quote">yea i think the integra would fit urs, I used a integra belt with mah type r swap. </TD></TR></TABLE>
wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg »</TD></TR><TR><TD CLASS="quote">Im pretty sure I used the Del Sol belt. It barely fit but it did fit. If that doesnt work try the 94-97 integra belt.</TD></TR></TABLE>
and wrong again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xpwex »</TD></TR><TR><TD CLASS="quote">I tried using the Integra one and the Del Sol but there both the same due to it having a bigger pulley on the compressor .....here the solution a B-Series motor has a 33" belt and when your using a B-series bracket for A/C and a SOHC compressor you have to use a 31" or 32" belt ...... thanks again....</TD></TR></TABLE>
are you using the P54 or the P72? the p72 is the ITR and will not work with the SOHC compressor, so now that is out in the open, using the p54 bracket, the SOHC compressor will work all long with the SOHC belt.
wrong
and wrong again.
Re: p54 or P72 A/C Bracket with SOHC Compressor what belt size(searched) (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
wrong
and wrong again.
are you using the P54 or the P72? the p72 is the ITR and will not work with the SOHC compressor, so now that is out in the open, using the p54 bracket, the SOHC compressor will work all long with the SOHC belt.</TD></TR></TABLE>
I actually using the p54 bracket and the p72 pulley and tensioner.... I have both brackets P54 and P72 they look the same.....but who knows my a/c works again thankx
wrong
and wrong again.
FeelTheBass
05-15-2014 08:59 AM
90civichbsi
08-10-2006 11:45 AM
