iac valve
the hoses that go on there have coolant/antifreeze in them, they're not vacuum lines. they should go on and look straight when on. if i mixed mine up on my car they would look kinked. hope that helps.
if you're looking at the motor the line on the left comes from the sensor under the throttle body which comes off the head. the one on the right is from the water pipe.
LSej1
Honda Civic (2001 - 2005)
Sep 4, 2017 09:45 PM
