ls-vtec is it worth it?
Old Oct 20, 2006 | 07:27 AM
keath's Avatar
Default ls-vtec is it worth it?
What's up? Ls-v, is it worth it? I've been doing research I'm hearing Ls-v is reliable, it has both torque and hp. However, I'm hearing "if it's all that good honda wouldn't do it in the first place," and "it's shitty! (whose had an ls-v)"
I've read about a 700 hp plus ls-v (full-race civic) and i was amazed. I want all-motor setup then a stage 3-4 full-race turbo kit.
I'd perabaly get a b18c5, h22a, b18c1 but you see I got oly bout 80k on my ls n if only i had the $. Any advice would be appreciated.
Old Oct 22, 2006 | 11:13 AM
na+b18c_hatch's Avatar
Default Re: ls-vtec is it worth it? (keath)
this is one of those topics thats mostly personal opinion. i've ridden in a built all-motor ls-vtec 2nd gen integra and it pulled very hard. however a built all-motor gsr or type r would pull hard too. i didnt use to like ls-vtec, but i think now that you see more of them, and more people have built them right they are more reliable than before. i would say go for it if you have a pretty fresh ls motor already in your car. good luck.
Old Oct 22, 2006 | 01:31 PM
drk_fly's Avatar
Old Oct 22, 2006 | 02:03 PM
shortyz21's Avatar
Default Re: (drk_fly)
http://www.c-speedracing.com/h...c.php
Old Oct 22, 2006 | 09:27 PM
drumking15's Avatar
f22/h22 vtec 2.3l great roque for n/a w/ def option to boost....run ethier a h tranny or be a balla and get a H2B kit and run a b hydro tranny...thing will def move!
and this is coming from a current boosted ls/v...runnin 9:1cr in 1857cc....the ls's stroke is nice off the line...and i cant complain about the top end efficency of the gsr head....thing just rips
Old Oct 23, 2006 | 06:10 AM
b18sihatch's Avatar
honda did do that in the first place, look at GSR itr ECT
1.8L block (high compression) and VTEC
Old Oct 23, 2006 | 07:04 AM
TurboCoop's Avatar
Default Re: ls-vtec is it worth it? (b18sihatch)
do it and do it right and it will be fine, dont go half *** with cheap parts, and dont beat on it all day and you will have a nice reliable motor. I have one btw and vtec is great
Old Oct 25, 2006 | 05:46 PM
blkteg95's Avatar
Read this for a reliable LS_VTEC (How to build a "reliable" lsvtec/b20vtec) search for this Great write up.
Old Oct 31, 2006 | 08:43 PM
Targa4Life's Avatar
Default Re: ls-vtec is it worth it? (blkteg95)
I have an LS/VTEC and it works amazingly.... Only thing is, I tried to cheap out in the beginning and I just had to go back a fix it because I never worked right. Now that I have the way it should be.... Making more than 300whp (with boost)
Buzz_Lightyear
Aug 20, 2009 09:31 AM
THEDirtyDseriesWOOT
Apr 17, 2007 08:23 AM
keath
Oct 29, 2006 04:13 PM
keath
Oct 21, 2006 08:06 AM
shift6
Mar 9, 2003 02:52 PM
