GSR throttle cable HELP!
Old Oct 19, 2006 | 11:35 PM
SOHCrx's Avatar
Default GSR throttle cable HELP!
I put a j-spec GSR in my 98 civic sedan using a 98 civic throttle cable with the jdm gsr throttle cable bracket (all on the gsr manifold / throttle body). the cable has too much slack so we extended the bracket and it covered the gap but i cant accelerate fast and the cable gets stuck. tried a gsr throttle cable also with no luck. all in all neither throttle cable fits correctly. does anyone know which is the correct cable and/or bracket to use so i can better my situation? thanks
Modified by SOHCrx at 1:35 AM 10/20/2006
Modified by SOHCrx at 10:03 PM 10/21/2006
Old Oct 20, 2006 | 01:52 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: GSR throttle cable HELP! (SOHCrx)
99 Civic Si cable should work fine.
Old Oct 20, 2006 | 10:07 AM
SOHCrx's Avatar
Default Re: GSR throttle cable HELP! (JDM_Ej)
99 si cable with the throttle cable bracket on the car? or do i have to switch it with the usdm one perhaps?
import-tooner
Jan 25, 2011 05:30 AM
highliner82
Dec 1, 2010 05:35 PM
IgnitionZ055
Apr 7, 2008 02:22 PM
SpoonEk253
May 27, 2006 06:20 PM
zm_dawg
Jul 12, 2004 09:53 AM
