Clutch pedal sensor?
Old Oct 19, 2006 | 08:18 PM
MadCityLude
Guest
Posts: n/a
Default Clutch pedal sensor?
What is it for? I was under my dash looking around to try and figure out why my brake lights aren't working and I noticed 2 places on the clutch pedal for plugs - neither of which are hooked up. What do they do? Obviously they aren't necessary, but can someone tell me more info on them, I would like to hook them up.
Old Oct 20, 2006 | 04:50 AM
preludeguy_92's Avatar
Default Re: Clutch pedal sensor? (MadCityLude)
one is to disengage cruise control and one is to lock out the ignition if the pedal is not depressed.
Old Oct 20, 2006 | 05:35 AM
Revi's Avatar
Default Re: Clutch pedal sensor? (preludeguy_92)
Yeah that ignition one has to be hooked up in order to turn on the car. I dont know how you are ever getting your car started if that is not plugged in?
Old Oct 20, 2006 | 07:40 AM
prelude_h22vtec's Avatar
i got mine bypassed.....
Old Oct 20, 2006 | 07:42 AM
92SleeperH23's Avatar
Default Re: (prelude_h22vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_h22vtec &raquo;</TD></TR><TR><TD CLASS="quote">i got mine bypassed.....</TD></TR></TABLE>
Same here. One day it just went out on me so I just jumped it, then it dawned on me that I could interrupt the jumper with a switch.
So now I have a kill switch. Wooo.
Old Oct 20, 2006 | 08:27 AM
sleepyH22's Avatar
yeah great to let every one know where ya kill switch is....durrrr...
Old Oct 20, 2006 | 09:08 AM
mgags7's Avatar
My car used to be an auto...and I never bothered to hook that thing up....its so much easier when I'm working on my car....all I have to do is keep it in neutral and I can just reach in the window to start it
Old Oct 20, 2006 | 09:11 AM
MadCityLude
Guest
Posts: n/a
Default Re: (bb4ever)
My chassis was also an Auto - converted to manual. Is that why its not hooked up? How would I go about doing it?
Old Oct 20, 2006 | 09:13 AM
mgags7's Avatar
Yea thats why....if you want to hook it up, you need to wire it inline with the starter cut relay...if autos even have that relay....
you are gonna want to look through the helms diagrams for exactly where they hook it in
Old Oct 20, 2006 | 09:40 AM
Default Re: (sleepyH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepyH22 &raquo;</TD></TR><TR><TD CLASS="quote">yeah great to let every one know where ya kill switch is....durrrr... </TD></TR></TABLE>
Too bad nobody even knows what city I live in, much less what my car looks like
Old Oct 20, 2006 | 09:55 AM
MadCityLude
Guest
Posts: n/a
Default Re: (92SleeperH23)
Has anyone ever done this?
I am more concerned with the cruise control part of it. My cruise doesn't work and I am thinking that is why.
Old Oct 20, 2006 | 09:57 AM
mgags7's Avatar
I never bothered with trying to make the AT cruise control work with the MT...it probably has inputs from the shifter connector, and I didn't care enough at the time to bother with it, and I doubt the clutch switch is the reason....
Old Oct 20, 2006 | 10:00 AM
red92s's Avatar
Default Re: (MadCityLude)
My clutch cruise switch failed, and I just jumped the switch with a short wire. Works fine. Only downside that is if you push in the clutch while using the cruise control, the revs will climb quickly.
Old Oct 20, 2006 | 12:34 PM
92_VTEC_lude's Avatar
how did you bypass the clutch pedal? I searched all over and could not find how to bypass the clutch pedal to install a AUTOSTARTER in my Prelude, it is getting cold in Canada now..... Please help me with a simple how-to or a link of how-to bypass the clutch pedal... thankyou all..
UPDATE: I looked at my prelude manual and got it firgured out
this is how I bypass my clutch pedal today
WARNING I never have my car in any gear when I park it, so install a autostarter in a manual car with this bypass clutch mod at YOUR OWN RISK...
Look up next to the clutch pedal and you will find 2 switches, the pink one is for cruise control, the yellow one with 2 wires (BLACK and BLACK/GREEN) is what you need, unplug the yellow end, at about 1 inch away from the end plug, strip back a little (1/4 inches or so) of the outer jacket on the 2 wires, twist them wires together, solder the wires if you can or you put electrical tape around both wires. I also installed a 2ways autostarter on it today and the car start fine (using key or remote) without depressing the clutch pedal....
Modified by 92_VTEC_lude at 4:27 PM 10/20/2006
Modified by 92_VTEC_lude at 9:38 AM 10/21/2006
Old Oct 20, 2006 | 11:05 PM
Default Re: (92_VTEC_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_VTEC_lude &raquo;</TD></TR><TR><TD CLASS="quote">how did you bypass the clutch pedal? I searched all over and could not find how to bypass the clutch pedal to install a AUTOSTARTER in my Prelude, it is getting cold in Canada now..... Please help me with a simple how-to or a link of how-to bypass the clutch pedal... thankyou all..
Just make sure to leave that **** in neutral
I know I don't need to tell you but I've seen people expletive it up and ruin cars
Old Oct 20, 2006 | 11:09 PM
MadCityLude
Guest
Posts: n/a
^^ For sure, that could be a tragedy
Old Oct 21, 2006 | 08:39 AM
thanks for the reminder, edited my reply with a warning now...
Old Oct 21, 2006 | 10:09 AM
SKDRCR's Avatar
yep me too, no sideload on the crank when I start it
Old Oct 21, 2006 | 10:11 AM
SKDRCR's Avatar
Modified by 92_VTEC_lude at 9:38 AM 10/21/2006</TD></TR></TABLE>
you know you can just pull the connector and put a jumper wire in it,
wrap it in some electrical tape and be done with it, takes 3 minutes.
Old Oct 25, 2006 | 07:41 PM
Default Re: (SKDRCR)
to hook the clutch pedal to the automatic interlock system isnt that hard i just looked over the helms wiring diagrams for the clutch lockout and the Automatic interlock system and figured it out
Ej8 d16
Oct 11, 2013 05:31 PM
moz92
Aug 24, 2008 03:38 PM
yaleforizzle
Dec 8, 2003 06:34 AM
p0pe
Sep 20, 2003 07:52 PM
p0pe
Sep 19, 2003 09:53 AM
