Alternator belt snapped and...
Old Oct 19, 2006 | 07:02 PM
GSRNetics's Avatar
Default Alternator belt snapped and...
....and it threw my A/C line off. I can't pinpoint were the noise is coming from, but it seems like the main pulley ISN'T turning due to being bound up. I'm pretty sure I can replace the belts, I'm just not sure if any other kind of damage is done. I was in 2nd gear, at around 4K RPM and I give about 50% throttle and the belt snaps giving me all these problems. Is this common noise from a simple alt. belt snap?
Old Oct 19, 2006 | 07:27 PM
JasonST's Avatar
Default Re: Alternator belt snapped and... (93DALS)
Get the alternator belt soon before ur battery is dead. Put the a/c belt back on, tighten em down and see if it still makes the noise. What kind of noise are u hearing?
Old Oct 19, 2006 | 09:03 PM
92DAIntegraXSI's Avatar
the noise could be th AC idler pulley mine just went bad and when it seized it backed the bolt out of the bracket causing the pulley to fall off and the ac belt to fall off and take out all 3 belts at once it sucked especialy at 3am
jdmme09
Feb 15, 2009 06:16 PM
GSRpoweredSI
Jun 20, 2007 01:13 PM
MrEg
Oct 15, 2003 08:42 AM
stRodda
Sep 12, 2003 04:42 PM
