squealing belt
Old Sep 12, 2003 | 04:18 PM
stRodda's Avatar
Default squealing belt
my alternator belt made a very annoying high pitched noise, so i took it to the shop and they tightened the alt pulley. but now, majority of the time, it makes the same noise on startup, but then stops after a couple seconds. is it just a wornout belt or could be it something else?
Old Sep 12, 2003 | 04:34 PM
Quik Chris's Avatar
Default Re: squealing belt (stRodda)
Did you tension the belt by using a prybar on the alternator then tightening the top bolt?
Old Sep 12, 2003 | 04:42 PM
RCautoworks's Avatar
Default Re: squealing belt (Quik Chris)
Take it back to the shop and tell them to fix it right, if its the alternator belt all you do is loosen the top nut, stick a pry bar in there and pull so it gets tight.
Coroner
Sep 20, 2006 05:37 PM
VTECth1s
Aug 30, 2006 10:24 PM
higgunscrx
Jun 15, 2006 05:11 PM
.Noah Fecks
Feb 8, 2005 12:31 PM
519[H]Si
May 25, 2004 09:25 PM
