How do i remove the CAM GEARS CAMSHAFTS! PIN KEEPS BREAKING
Old Oct 19, 2006 | 05:06 PM
drumminforev's Avatar
Default How do i remove the CAM GEARS CAMSHAFTS! PIN KEEPS BREAKING
What do i need to stick through the cam holder into the camshaft THAT WONT BREAK TO GETT THE CAM GEARS OFF. I used punch pins and it worked til it bent, then another one that broke, and broke a punch of other things.
WHAT IS REALLY supposed to be used in that little hole, what did honda have in mind.
Old Oct 19, 2006 | 05:26 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: How do i remove the CAM GEARS CAMSHAFTS! PIN KEEPS BREAKING (drumminforev)
An impact wrench may help as well. I usually wrap a strap wrench around the cam gear to hold it.
Old Oct 19, 2006 | 05:30 PM
Default Re: How do i remove the CAM GEARS CAMSHAFTS! PIN KEEPS BREAKING (Dogginator)
If i had an impact wrech i would be using it. I dont know what a strap wrench is.
HOW DO I REMOVE THE CAM GEAR SOMEONE
Old Oct 19, 2006 | 05:38 PM
Beau Gotti's Avatar
get a big *** screwdriver
snap on makes a tool that keeps the cam gears in place.
Old Oct 19, 2006 | 05:45 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev &raquo;</TD></TR><TR><TD CLASS="quote">I dont know what a strap wrench is.
Old Oct 19, 2006 | 05:46 PM
Thanks for that, anything that i can use that i can walk down to the store and buy now. Cant wait for shipping
And i dont see what a big *** screwdriver is going to do for me. The hole is 3mm big. Do you know what im talking about?
Old Oct 19, 2006 | 05:48 PM
Dogginator's Avatar
Daisy... Daisy...
Sears' site has strange links for pictures. Try this:
Old Oct 19, 2006 | 05:50 PM
At what angle would i have to stick the screwdriver to stock the cam geras from spinning
Old Oct 19, 2006 | 05:51 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Are the cams still in the head?
Get a wrench, or ratchet, along with a rubber mallet, and then just have someone hold the shaft, or hold it yourself,
Support the wrench enough that you can hit it, and go from there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Sears' site has strange links for pictures. Try this:
And is that just supposed to go around the cam gear and grip it
Old Oct 19, 2006 | 05:52 PM
Beau Gotti's Avatar
may not be the best way, but ive done it like this
stick the screw drive though the cam gear, inbetween the spokes, and take the VC off, and let it rest on the head, id put a towel or something down where it rest on the head.
ive always done this, and never hurt anything, but if it does look like something bad will happen, then stop.
Old Oct 19, 2006 | 05:54 PM
Default Re: How do i remove the CAM GEARS CAMSHAFTS! PIN KEEPS BREAKING (CleanLikeJdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">Are the cams still in the head?
Support the wrench enough that you can hit it, and go from there.</TD></TR></TABLE>
I wish i knew what u meant by all that. How do i hold the cams if they are under the cam plate and all that.
Old Oct 19, 2006 | 05:55 PM
Beau Gotti's Avatar
the cam spoke will hit the screw driver, which it is laying on the head so it will stop the cam from turning...
Old Oct 19, 2006 | 05:59 PM
Dogginator's Avatar
Daisy... Daisy...
?</TD></TR></TABLE>
Yes. It works quite well.
Old Oct 19, 2006 | 06:01 PM
Default Re: (GECKObeau)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GECKObeau &raquo;</TD></TR><TR><TD CLASS="quote">may not be the best way, but ive done it like this
ive always done this, and never hurt anything, but if it does look like something bad will happen, then stop.</TD></TR></TABLE>
Well i got it. Screwdriver tequnique works easy. I stuck it through the cam gear holes so it was against the head. Thanks guys
Old Oct 19, 2006 | 06:06 PM
Beau Gotti's Avatar
ya im the **** LOL jk
Old Oct 19, 2006 | 06:28 PM
Hype-R Stalker
If they Weren't in the head, I meant to say.
But I'm assuming the timing belt isn't on the gears anymore?
wlangeles
Apr 16, 2012 08:56 PM
kpjo4
Jul 11, 2009 06:44 AM
TB123
Mar 24, 2008 01:36 PM
aznej2
Apr 22, 2006 03:10 PM
94civicexlsvtec
Jul 30, 2005 02:52 PM
