strange sound from clutch when disengaged! help!!
Old Oct 19, 2006 | 07:54 AM
mr.si1's Avatar
Default strange sound from clutch when disengaged! help!!
so a couple weeks ago i noticed that after i start my car and depress the clutch it makes a stange "spinning /chattering" sound. the clutch and flywheel are only about a year old if that. it is an exedy stg.1 w/exedy lite flywheel. any ideas anyone. fluid level is at line. clutch pedal goes in and out fine and when the pedal is in, the sound goes away.????????????????????????????
Old Oct 19, 2006 | 09:40 AM
mr.si1's Avatar
Default Re: strange sound from clutch when disengaged! help!! (mr.si1)
anyone?
Old Oct 19, 2006 | 02:44 PM
96typeR's Avatar
throw out bearing...just a guess
Old Oct 19, 2006 | 08:48 PM
JimBlake's Avatar
Default Re: strange sound from clutch when disengaged! help!! (96typeR)
Just for grins, your terminology is backwards. You press down the pedal to DISengage the clutch. So your noise is only happening when the clutch is engaged.
Probably throw-out bearing, but here's how to check.
Idle in neutral, it should be making the noise.
Press in the clutch quickly & completely. A noisy throw-out bearing will get quiet instantly. A noisy bearing in the transmission will take a second or 2 before it coasts to a stop.
Old Oct 19, 2006 | 09:50 PM
hefftone79's Avatar
I have the same clutch/flywheel on my 89 Si, and it's doing the same ****. Mine started doing it instantly after i pulled a ricer 2-3. Sounds Like a scratching sounds, or dry leaves blowing across asphalt.
I think Mine was out of adjustment, and I likely damaged the friction disc.
suje
Oct 27, 2011 02:28 PM
CubbyChowder
16
May 4, 2010 02:17 PM
garados
Dec 20, 2002 03:17 PM
Que
Jan 17, 2002 10:37 PM
