Distributors...
I'm fed up with the honda-tech search engine!
Will a obd1 vtec distributor work (without problems) with a non-vtec ecu?
Basically what I need to know is if all b-series distributors from the correct obd dates are the same.
Think it should work just fine. If u have the origanal no vtec distributor use that and just swap the ignitor and coil into it. If u have it lieing around just put it on and take it for a quick drive see if it works. I used ls dizzy parts on my h22 for a bit and it worked fine.
