please help with this question sice honda-acura wont help
http://www.honda-acura.net/for...52618
click the link and reply here or there thanks in advance!!!
try starting it with ether or that carb ****... if it starts and runs then dies onces all the ether is used, its a fuel problem'
do you have the correct fuel pressure? is fuel getting to the rail? are hte injectors even working correctly?
firing order right?
firing order right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by huevosrancheros »</TD></TR><TR><TD CLASS="quote">You could have a clogged fuel filter????
He just replaced that.
Sounds like a fuel delivery problem. You've solved the electrical, and in regards to fuel you did injectors, filter, tank, but what about the fuel switch or any of the fuses in regard to it? Happend to my old 91 integra....
cool ill check the fuses and how do i check fuel switch! what fuse can it be! any help appreciated and thanks to all
crnimacak
Apr 21, 2006 10:11 PM
