(already searched) B16 pistons in stock ls b18a1 question..
Old Oct 18, 2006 | 08:31 PM
KAWZ92DA's Avatar
Default (already searched) B16 pistons in stock ls b18a1 question..
My question is, How much more horsepower could you get from installing b16 pistons into a stock ls b18a1? Anybody?.
Old Oct 18, 2006 | 08:34 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (already searched) B16 pistons in stock ls b18a1 question.. (KAWZ92DA)
Do it and dyno. That's the only way you will know for sure.
(not trying to be a dick)
Old Oct 18, 2006 | 08:48 PM
KAWZ92DA's Avatar
Hey thats so true!! But the question might be for those who have done it already.. thanx!
Old Oct 19, 2006 | 07:28 AM
Sam92Teg's Avatar
PR3's yeild 10.8/1 compression, P30's yeild 11/1, and PCT's yeild 12/1
Which do you plan on using?
And most people upgrading their pistons are swapping cams and valve train to take advantage of the raised compression. Then you have I, H, E differences and the tuning aids used to tune. Now do you see why we can't give you a number?
Ok, I give, 10 hp for each point in compression raised, lol.
Old Oct 19, 2006 | 07:37 AM
Dark_Teg's Avatar
I just installed some PR3's in my B18A1. But like was already mentioned above I also installed a ported JG head, crower 402 cams and a Blox intake manifold so I really wont know how much the pistons helped.
Going from the stock 9.2 to1 compression of the B18A1 to 11 to 1 compression should be worth a noticeable gain in HP and torque throughout the power band which is way more important than a few peak HP.
Old Oct 19, 2006 | 12:03 PM
PickleTeg's Avatar
Default Re: (already searched) B16 pistons in stock ls b18a1 question.. (Dark_Teg)
The compression raise will really benefit from better cams. If you are going to take the head off it would be a cinch to put in some Crower 403/404s and the supporting valvetrain. With 404s, PR3s and tuned on a dyno I bet you put 20-25 more ponies to the ground.
Old Oct 19, 2006 | 09:42 PM
Vince909's Avatar
a1320honda
Jan 14, 2009 06:30 AM
ls_bitik
May 27, 2007 11:56 AM
blundar
Apr 26, 2006 09:46 PM
bens_redeg
Mar 17, 2004 03:26 AM
EGHatchy
Jun 24, 2002 08:34 AM
