Help with compression #s
Old Oct 18, 2006 | 08:06 AM
d16racer's Avatar
Default Help with compression #s
ok i have a d16y8 bored .25 over with srp 9:1 pistons in it the motor was built about 4000 miles ago and i have been running about 14psi of boost on it aproximitly what should the compression reading be? like around 160 ish?
Old Oct 19, 2006 | 08:54 AM
d16racer's Avatar
bump for answers
Old Oct 20, 2006 | 07:30 PM
ddd4114's Avatar
Default Re: (d16racer)
My guess would be 160ish, but that's not the important part.
As long as there is little variation between the readings, you're fine. If you think the numbers are low, add a drop of oil in.
peakboosth22
Jun 20, 2006 08:55 AM
jdm2teg
Dec 14, 2005 01:41 PM
genop
Sep 17, 2003 10:45 PM
95c1v1cs1
Apr 21, 2003 11:29 AM
