Anybody done a manifold like this before?
Old Oct 18, 2006 | 05:59 AM
Fred Allen Burge's Avatar
Default Anybody done a manifold like this before?
I like the way it looks to just french the runners together instead of using a formal collector. I'd like to see one like this for a 4 cyl or a V6.
Fred
Old Oct 18, 2006 | 06:12 AM
Finest's Avatar
Default Re: Anybody done a manifold like this before? (Fred Allen Burge)
Whoa!
Any pictures of the inside?
Old Oct 18, 2006 | 06:37 AM
Default Re: Anybody done a manifold like this before? (Finest)
Haven't found any yet, here's a shot of one for a 4 cyl. Apparently this is how HKS does most of they're manifolds, or used to at least.
Fred
Old Oct 18, 2006 | 06:46 AM
drumking15's Avatar
neukin makes one that merges all 4 together....and the turbo flange is centered to the head flange...not offset like those pictured
Old Oct 18, 2006 | 06:47 AM
FastCougar's Avatar
How would you "french" together a V6? Impossible since the headers are 2 banks of 3. You need some type of intermediate up-pipe that merges the two banks together before the turbo flange. Make sense?
Old Oct 18, 2006 | 07:02 AM
Default Re: Anybody done a manifold like this before? (FastCougar)
I meant for a twin turbo V6 setup, two 3 cylinder manifolds.
Fred
Old Oct 18, 2006 | 07:08 AM
fabnewb's Avatar
this type of collector is used alot in bmw turbo apps.
Old Oct 18, 2006 | 07:15 AM
snoochtodanooch's Avatar
Default Re: Anybody done a manifold like this before? (fabnewb)
it's alot of welding and cutting too. It looks good but seems like alot of work.
Old Oct 18, 2006 | 07:23 AM
legendboy's Avatar
Default Re: Anybody done a manifold like this before? (snoochtodanooch)
ssautochrome?
Old Oct 18, 2006 | 07:41 AM
GeeGee's Avatar
It doesn't look that hard to cut. I could adjust my collector jig to a different angle and cut away.
Old Oct 18, 2006 | 08:28 AM
Default Re: Anybody done a manifold like this before? (GeeGee)
not a chance, look at the far right runner in the very first picture. The cut into that tube goes for more than 8 inches, and it follows the curve of the other tube which is also cut. It isn't a straight line, your jig wouldn't work.
Old Oct 18, 2006 | 08:36 AM
GeeGee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">not a chance, look at the far right runner in the very first picture. The cut into that tube goes for more than 8 inches, and it follows the curve of the other tube which is also cut. It isn't a straight line, your jig wouldn't work. </TD></TR></TABLE>
you're right, but i was refering to making a collector out of straight pipe using the same concept instead of bends like that. I have no idea how they would cut something like that.
Old Oct 18, 2006 | 09:01 AM
legendboy's Avatar
i imagine they cut the tubing on a horizontal band saw
Old Oct 18, 2006 | 10:00 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">it's alot of welding and cutting too. It looks good but seems like alot of work.</TD></TR></TABLE>
But most importantly, does it work better than a conventional collector?
Old Oct 18, 2006 | 10:19 AM
.nate's Avatar
I have the Neukin one in my hands the other day... it looked pretty nice, but the dyno will tell once I tune the car....
Old Oct 19, 2006 | 08:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">
But most importantly, does it work better than a conventional collector? </TD></TR></TABLE>
probably not a noticeable amount, the velocities probably drop off alot and the turbulence has to be ridiculous. Still looks fancy shmancy
Flashmn
Welding / Fabrication
Aug 15, 2009 02:17 PM
kierkegag
Jun 25, 2006 04:45 PM
dan_w_82
Jan 18, 2005 09:29 AM
EV1L SI
Jul 9, 2003 08:08 PM
DIY_Racing
Jan 1, 2003 05:49 PM
