found ls block. what pistons, rods should i use? on a budget.
Old Oct 18, 2006 | 05:54 AM
mr.si1's Avatar
Default found ls block. what pistons, rods should i use? on a budget.
ok so i finally found a descent ls block off a buddy. it will be going in my em1. should i use the b16 pistons and rods if there ok, or something else? please help i'll be doing it on a budget of about 1500 bucks or so. i currently run sk2 stg.1 cams also, should i swap them out? looking for descent street poooower.
Old Oct 18, 2006 | 06:08 AM
xDicktonesx's Avatar
Default Re: found ls block. what pistons, rods should i use? on a budget. (mr.si1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.si1 &raquo;</TD></TR><TR><TD CLASS="quote">ok so i finally found a descent ls block off a buddy. it will be going in my em1. should i use the b16 pistons and rods if there ok, or something else? please help i'll be doing it on a budget of about 1500 bucks or so. i currently run sk2 stg.1 cams also, should i swap them out? looking for descent street poooower.</TD></TR></TABLE>
buy an ls crank, ls rods, re-use your p30s if the machinist can get em off your b16 rods without dicking them up.
the crank and rods shouldnt run you more than 100 bucks if you search around.
use the rest of your money for the machine work, a nice header, and a GE lsvtec kit. tuning, and a socketed ecu with which to tune
Old Oct 18, 2006 | 07:36 AM
mr.si1's Avatar
Default Re: found ls block. what pistons, rods should i use? on a budget. (xDEFTONESx)
ok thanks, should i change out the cams too? or are they sufficiant? could i use ctr pistons, and still be streetable? thanks again for all your info.
Old Oct 18, 2006 | 07:46 AM
ctr in lsvtec on pump gas = no.
cams are fine.
Old Oct 18, 2006 | 07:50 AM
acydphryck's Avatar
get an engine management setup and tune it. also, i'd get ARP rod bolts for your LS rods just for peace of mind
Old Oct 18, 2006 | 07:53 AM
Default Re: found ls block. what pistons, rods should i use? on a budget. (acydphryck)
as a matter of fact, jsut search username bambam and read his "how to build a reliable lsvtec thread" that should answer anything else you need to know. the priciples are simple, but the devil is in the details.
Old Oct 18, 2006 | 08:24 AM
ExSohcEk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDEFTONESx &raquo;</TD></TR><TR><TD CLASS="quote">as a matter of fact, jsut search username bambam and read his "how to build a reliable lsvtec thread" that should answer anything else you need to know. the priciples are simple, but the devil is in the details.</TD></TR></TABLE>
Hey thanks for that, i know alil bit, but i'm really wanting more power from my swap...without the motor blowing, so that helped ALOT
Old Oct 18, 2006 | 09:38 AM
mr.si1's Avatar
Default Re: found ls block. what pistons, rods should i use? on a budget. (ExSohcEk)
well you guys are the shizznit. thanks for all your help with my issue. also, to make all fair, i do know quite a bit about painting(automotive) so to that if anyone needs some info i'm more than willing to lend my brain since you all have done so for me. thanks again all.
Old Oct 18, 2006 | 10:31 AM
ExSohcEk's Avatar
haha, same here.
ez2000si
Mar 4, 2013 01:12 PM
knightsef-eg
Jun 17, 2012 01:18 AM
CTR_B
Nov 9, 2008 05:54 PM
jdmbeegee
Sep 5, 2006 10:04 PM
Krussty420
Sep 27, 2004 11:29 PM
