does anyone use nitrous?
Old Oct 18, 2006 | 04:31 AM
HONDAVTIS's Avatar
Default does anyone use nitrous?
do u guys know what kinds of car could use nitrous. only turbocharged? or also can be used in normal stock car? is it bad for engine?.......................
Old Oct 18, 2006 | 04:47 AM
Ross 2.0's Avatar
In a Junkyard near you.
well just about any motor could use nitrous at diffrent levels.
You need to go to google and do some more research before buying anything. Also this really doesn't belong here.
But I won't report it because nothing will happen...
Old Oct 18, 2006 | 07:11 AM
standbackimapro's Avatar
You can run nitrous on any car, Just depends on how much you use
You can run a 25 shot of nitrous on a stock motor and it should be fine
But if you have a midifed motor, thats able to handle more nitrous than you can run a higher shot
Old Oct 18, 2006 | 08:19 AM
iam7head's Avatar
Default Re: (standbackimapro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro &raquo;</TD></TR><TR><TD CLASS="quote">You can run nitrous on any car, Just depends on how much you use
But if you have a midifed motor, thats able to handle more nitrous than you can run a higher shot</TD></TR></TABLE>
or any internal combustion motor, um...lawn mower
do alot more research before blewing your motor up, it's a cheap way to gain some power, but at the same time, a fast way to have a bunch of broken parts if you don't know what you are doing
Old Oct 18, 2006 | 03:33 PM
BlUAc's Avatar
Default Re: (iam7head)
there is a tuner shop here in modesto who experimented with nos in a single motor he started off at a 25 shot and worked his way up to 300 shot to see how much juice it can handle and the motor still didnt blow just goes to show if you do a proper setup your motor can hang
ps not saying to do it just saying a stock motor can take a lil nos
Old Oct 18, 2006 | 03:58 PM
Ross 2.0's Avatar
Default Re: (BlUAc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlUAc &raquo;</TD></TR><TR><TD CLASS="quote">there is a tuner shop here in modesto who experimented with nos in a single motor he started off at a 25 shot and worked his way up to 300 shot to see how much juice it can handle and the motor still didnt blow just goes to show if you do a proper setup your motor can hang
ps not saying to do it just saying a stock motor can take a lil nos</TD></TR></TABLE>
thanks for your advice but please use puntuation!!
Old Oct 18, 2006 | 05:57 PM
pos_cd5's Avatar
Default Re: (Ross 4107)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross 4107 &raquo;</TD></TR><TR><TD CLASS="quote">
thanks for your advice but please use puntuation!!</TD></TR></TABLE>
punctuation
Old Oct 18, 2006 | 08:56 PM
02 accord's Avatar
Default Re: (pos_cd5)
Punctuation isn't spelling.
Old Oct 18, 2006 | 10:26 PM
gosu08's Avatar
Default Re: does anyone use nitrous? (HONDAVTIS)
i have a 94 accord ex and im running 75 shot of nitrous and my car is running just fine. just remmeber you have to run 91 octane for the combustion factor
Old Oct 18, 2006 | 10:34 PM
pos_cd5's Avatar
Default Re: does anyone use nitrous? (gosu08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gosu08 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 94 accord ex and im running 75 shot of nitrous and my car is running just fine. just remmeber you have to run 91 octane for the combustion factor</TD></TR></TABLE>
dont you have to run colder plugs also?
Old Oct 18, 2006 | 11:34 PM
gosu08's Avatar
Default Re: does anyone use nitrous? (pos_cd5)
ahh yes forgot about that one. yeah you have to run colder spark plugs too. im running ngk 2 steps colder plugs. cost me $10 at o'reilleys or however you spell it for all 4.
Old Oct 19, 2006 | 07:05 AM
HandoEX's Avatar
-use 2 step colder plugs (Zex makes some or NGK bkr7e)
-always use premium fuel (91+) to avoid detonation
-generally a 75 shot will be fine on a stock motor if everything is set up properly
Read up on things like rpm-activated window switches and bottle heaters. Also check out manufacturers websites (Zex's site goes over the basics).
PS- Accords love nitrous
Old Oct 19, 2006 | 04:42 PM
BlUAc's Avatar
Default Re: does anyone use nitrous? (HandoEX)
oh sorry ,,.,..,. there just add them in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HandoEX &raquo;</TD></TR><TR><TD CLASS="quote">-
yes they do, well all singles love it.
Old Oct 19, 2006 | 11:17 PM
pos_cd5's Avatar
Default Re: does anyone use nitrous? (BlUAc)
i also read that you shouldnt use platnium plugs with nitrous. anyone know the reason why?
Old Oct 19, 2006 | 11:26 PM
cambopheonix56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HandoEX &raquo;</TD></TR><TR><TD CLASS="quote">-use 2 step colder plugs (Zex makes some or NGK bkr7e)
PS- Accords love nitrous </TD></TR></TABLE>
Retard the timing as well a few degree's.
Old Oct 20, 2006 | 05:24 AM
HandoEX's Avatar
Default Re: does anyone use nitrous? (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">
Retard the timing as well a few degree's.</TD></TR></TABLE>
Forgot to add that. Zex reommends pulling no timing for a 55 shot, 2 degrees for a 65 shot, and 4 degrees for a 75.
Old Oct 20, 2006 | 07:06 AM
KillerElfboy's Avatar
how much of a diference will a 75 shot make?
Old Oct 20, 2006 | 08:45 AM
HandoEX's Avatar
Default Re: does anyone use nitrous? (KillerElfboy)
Here are my times with and without nitrous with the stock tranny and after the tranny swap...
AUTO
no nitrous: 17.2
with 75 shot: 15.3
5-SPEED
no nitrous: 16.3
with 75 shot: 14.9
s2geezykubo
Honda S2000
Aug 9, 2006 04:38 PM
hondatuner20
Jun 4, 2005 02:31 PM
BME1986
Jun 16, 2004 12:16 PM
Gen2Integra
Jan 29, 2004 05:08 PM
NewbieGuy
Oct 11, 2001 08:24 AM
