Walbro Fuel Pump install...
Old Oct 17, 2006 | 11:34 PM
boostnubII's Avatar
Default Walbro Fuel Pump install...
my stock fuel pump burnt out *(i think) and i will be changing it out with a Walbro 255. im not going to ask how... but is there an archived thread that might give an informative step by step... last thing i want is a fire under my back seat... thx much...
Old Oct 17, 2006 | 11:45 PM
boostnubII's Avatar
Default Re: Walbro Fuel Pump install... (boostnubII)
im sure its all the same...but the fuel pump will be going into 95 civic EX coup
Old Oct 18, 2006 | 12:58 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Make sure you release the fuel pressure first. Otherwise you will have a nice puddle of gas under your back seat. After the presssure is released, take off the fuel pump cover, remove the hoses and wires and remove the pump. Take note on the way it came out, because you don't want to expletive it up putting the assembly back in, or your gas gauge will be incorrect.
Edit: I hope you car is turbo. A Walboro 255 is overkill if you don't.
Old Oct 18, 2006 | 09:22 AM
boostnubII's Avatar
Default Re: Walbro Fuel Pump install... (JDM_Ej)
motor has T3/T4.
Old Oct 30, 2006 | 12:39 PM
Shoei7's Avatar
I have a doubt... what's the better: walbro 255 external or MSD 2225 external?..
I need to buy a fuel pump to my car, EG6 - B16A3 - turbo... using Venom fuel injectors 96 lbs..
Could you help me?
Sorry, my english is not so good..
I'm from Brazil...
Old Oct 30, 2006 | 08:00 PM
BoneStockDX's Avatar
Default Re: Walbro Fuel Pump install... (Shoei7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shoei7 &raquo;</TD></TR><TR><TD CLASS="quote">I have a doubt... what's the better: walbro 255 external or MSD 2225 external?..
I dont think you need an external fuel pump. Get the walboro 255lph IN-Tank fuel pump. Goes where the old pump goes and you wont have that annoying sound of the pump.
Old Oct 30, 2006 | 10:48 PM
91SiZ6's Avatar
My Walbro 190 came with installation instructions.
90 ef
Dec 2, 2009 05:33 PM
trooper0641
Jul 13, 2005 08:21 PM
wumba
Apr 7, 2005 10:08 PM
boostagsr17
May 20, 2004 12:59 PM
