Honda S2000 Honda S2000
My car idling rough and Gauge cluster is not working
Old Oct 17, 2006 | 10:47 PM
S2K Luver's Avatar
Default My car idling rough and Gauge cluster is not working
The car shakes and the check engine light is on but not blinking. The RPM part of the gauge clusters work but not MPH. The steering wheel feels a little harder to turn but not too hard.
Old Oct 18, 2006 | 04:40 AM
cmdr430's Avatar
Default Re: My car idling rough and Gauge cluster is not working (S2K Luver)
sounds like it could be a number of things....
first off, is the car modified at all? if so, what mods have you done?
have you purchased fuel recently?
driven in a major rain storm?
how old is the car?
how many miles are on the odo?
etc,etc....
Old Oct 18, 2006 | 06:28 AM
Luder94's Avatar
Rough idle + check engine light = missing cylinder (I'd take a look at cylinder #3). That's just a guess though.
As for your gauge cluster.....start checking fuses and your speed sensor.
Old Oct 18, 2006 | 06:33 AM
S2K Luver's Avatar
Default Re: My car idling rough and Gauge cluster is not working (cmdr430)
I had my valves changed out and head gasket.
Could it be a head gasket?
Old Oct 18, 2006 | 06:49 AM
cmdr430's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2K Luver &raquo;</TD></TR><TR><TD CLASS="quote">I had my valves changed out and head gasket.
Could it be a head gasket?</TD></TR></TABLE>
what happened?
did you misshift and over rev
have you done a valve adjustemt since they were installed?
Old Oct 18, 2006 | 07:05 AM
S2K Luver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">what happened?
have you done a valve adjustemt since they were installed?</TD></TR></TABLE>
Yes misshift so I replaced them.
I havent gotten an adjustment since.
Old Oct 18, 2006 | 11:19 AM
JDM knowledge's Avatar
does VTEC engage?
Old Oct 18, 2006 | 02:29 PM
S2K Luver's Avatar
Default Re: My car idling rough and Gauge cluster is not working (JDM knowledge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM knowledge &raquo;</TD></TR><TR><TD CLASS="quote">does VTEC engage?</TD></TR></TABLE>
no vtec the car wont rev past 7000
Old Oct 18, 2006 | 02:50 PM
cmdr430's Avatar
have you checked your oil level
sounds like it is im limp mode
Old Oct 18, 2006 | 04:45 PM
S2K Luver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">have you checked your oil level
sounds like it is im limp mode</TD></TR></TABLE>
Good oil levels
Speed sensor is most likely broken
But that wouldnt cause the horrible idle and shaking
maybe im missfiring or my head gasket is leaking im going to check it out tomorrow.
then when I have some money right now im going through hard times I'll get it fixed
Old Oct 18, 2006 | 08:04 PM
Luder94's Avatar
Horrible shaking and idle could be caused by a cylinder not firing. Check your spark plugs and your coilpacks. I'd start with cylinder 3. Just check it and tell me that I'm wrong so that I stop repeating myself.
shm91
Nov 9, 2013 05:28 PM
Shinny
10
Dec 24, 2011 11:56 AM
fudo1252
Feb 24, 2008 06:20 PM
h22a_junkie
Mar 7, 2006 03:40 AM
78vetteboy
Nov 3, 2005 10:18 AM
