Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
common to need wheel alignment after new tires installed ?
Old Oct 17, 2006 | 04:42 PM
Honda.F1's Avatar
Default common to need wheel alignment after new tires installed ?
I'm getting some snow tires and of course everyone wants to sell you 'road hazard' packages and everything else they can tack on to your bill.
The tire salesman said it is common to need a wheel alignment after getting new tires put on. They check alignment afterwards for free. I guess I can have them show me the alignment chart to make sure they are not screwing me.
I'm wondering if this is 1/2 way true or he's simply BSing me.
common to need wheel alignment after new tires installed or not ?
Thanks
Old Oct 17, 2006 | 05:20 PM
toyomatt84's Avatar
Sanji
An alignment is typically needed whenever the suspension is modified. And, he may be referring to wheel balancing, but I could be wrong. Wheels need to be balanced whenever tires are changed.
Old Oct 17, 2006 | 07:09 PM
nccivicracer's Avatar
u may need an alignment if theres a drastic change in tire size. most of shops will show u a specs sheet when the work is done.
Old Oct 18, 2006 | 02:30 PM
Perfectionist's Avatar
Default Re: common to need wheel alignment after new tires installed ? (Honda.F1)
Pure B.S. Although it may be wise to have the alignment checked to protect your investment in new tires, simply getting new tires does not cause the alignment to change.
Old Oct 18, 2006 | 04:35 PM
Boilermaker1's Avatar
Default Re: (nccivicracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nccivicracer &raquo;</TD></TR><TR><TD CLASS="quote">u may need an alignment if theres a drastic change in tire size. most of shops will show u a specs sheet when the work is done.</TD></TR></TABLE>
Not true at all.
Tires do not change the suspension geometry, they will only raise and lower the height of the entire car, the static height of the suspension is unchanged. If your alignment was good with spare donuts on, it'll be fine with 335/35/24s and anywhere in between.
CallMeKing
Apr 20, 2012 10:51 AM
sobey
Feb 16, 2009 06:03 AM
neopheus
Suspension & Brakes
Mar 17, 2005 08:02 PM
Type R 01
Oct 1, 2002 01:21 PM
GSblueRacing
Jul 6, 2002 10:47 PM
