cam torque spec
Old Oct 17, 2006 | 04:05 PM
bustdgst's Avatar
Default cam torque spec
anyone know the torque specs for cam caps and hold downs on a b16 head off a 2000 SI?
Old Oct 17, 2006 | 04:42 PM
bustdgst's Avatar
damn guys...someone gotta know!!!
Old Oct 17, 2006 | 06:39 PM
b19coupe's Avatar
Default Re: (bustdgst)
17 ft-lbs and 7.2 ft-lbs.
Old Oct 17, 2006 | 06:54 PM
an2ny888's Avatar
Default Re: (b19coupe)
i'm pretty sure it's 20 ft/lb and 7.2 ft/lb
Old Oct 17, 2006 | 08:07 PM
b19coupe's Avatar
Default Re: (an2ny888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">i'm pretty sure it's 20 ft/lb and 7.2 ft/lb</TD></TR></TABLE>
Just looked it up-you are correct. I still only torque the 12mm bolts to 17.5 ft-lbs.
I have the cams out every other week, so bolt stretch is a concern
Old Oct 18, 2006 | 02:29 AM
an2ny888's Avatar
haha i'm in the same boat, am actually thinking of buying new cam cap bolts, i don't trust the old ones after all the times i've swapped cams
Old Oct 18, 2006 | 05:59 AM
bustdgst's Avatar
awesome...ive been looking for this everywhere!!! thanks guys!!!
Old Oct 20, 2006 | 06:04 PM
jay-d-em's Avatar
anybody no whats that in inch pounds?
cause i have a torque wrench in inch pounds.
Old Oct 20, 2006 | 06:16 PM
DonF's Avatar
Default Re: (jay-d-em)
20 x12 or 17.5 x 12 I like the secoond one better.
EDIT 1 lb.ft =12 lb.in 20 lb.ft= 240 lb.in
Modified by DonF at 10:32 PM 10/20/2006
Old Oct 21, 2006 | 01:21 PM
jay-d-em's Avatar
Default Re: (DonF)
so you always mutiply ft. lbs by 12 to get in. lbs?
Old Oct 21, 2006 | 03:21 PM
bustdgst's Avatar
i think it was 86 inch pounds
Old Oct 21, 2006 | 04:32 PM
DonF's Avatar
On the 6mm bolts not the 8mm bolts you are correct.
hspoon
Nov 24, 2007 03:57 PM
m00nr0ck Si
Jan 1, 2006 11:39 AM
drudy
Jan 31, 2005 03:03 PM
Darkane
Jul 27, 2004 08:46 PM
Modifiedinteg
Dec 14, 2003 10:06 PM
