Valve Noise
Old May 4, 2002 | 09:58 AM
Hatch_Back_97's Avatar
Default Valve Noise
Hello, I am new to the honda world. Just sold my 170HP dual webber carbed 1984 RX7 GSL...fun car, my "new" Honda doesn't come close in speed and fun, but I love her. The only thing that pisses me off is the valve noise...it need adjusting, either a lifter loose or valve out of adjustment...but the engine purrs, just noise when accel and decell...help?
It's a 1997 Civic CX hatch back (Non-VTEC 1.6liter)
[Modified by Japanese_Rice_Magic, 6:58 PM 5/4/2002]
[Modified by Japanese_Rice_Magic, 6:59 PM 5/4/2002]
Old May 4, 2002 | 10:05 AM
Plan B's Avatar
Default Re: Valve Noise (Japanese_Rice_Magic)
The valves are quite easy to adjust, just a little patience is all that's needed. Mine always irritated me at an idle more than at acceleration. Maybe something else is loose, you should look into it.
Old May 4, 2002 | 03:25 PM
VTI_VTEC's Avatar
Default Re: Valve Noise (Plan B)
I had the same problem when idling, it turn out to be the fuel filter that was Fcuked
Old May 4, 2002 | 04:05 PM
hybrider's Avatar
Default Re: Valve Noise (VTI_V-TECH)
Old May 4, 2002 | 04:12 PM
JV's Avatar
JV
Who?
Default Re: Valve Noise (hybrider93)
All Hondas have a certain amount of "valve tap". Every single honda motor i've heard has that faint ticking. The only thing i've ever heard of, that made it go away is Amsoil....
But if it's excessively bad then it could need an adjustment. Never heard of a fuel filter change making it stop. How does that help?
Old May 5, 2002 | 07:35 PM
REDSOL's Avatar
Default Re: Valve Noise (JV)
same deal, dealer said all hondas have the valve tick. was advised to drive it till i hit the 90k mark (only 68k now) then get the timing belt and valves adjusted.
Old May 5, 2002 | 09:31 PM
M-EJ1's Avatar
Valve adjustment... just did it today with my car... no more (loud) ticking when I'm idling. I can't remember the interval, but my Chilton's manual for my 95 civic says that valve adjustments are part of the regular maintenance that should be done to your car. So, with that in mind, if your valves are audibly ticking and it's getting on your nerves, go ahead and have them adjusted (or grab a manual for your car and do it yourself )
RHCivic
Honda Civic (2001 - 2005)
Jun 21, 2018 08:35 PM
pityocamptes
26
Mar 25, 2016 10:23 AM
2003civichybrid
Aug 15, 2014 06:05 PM
ki0326
Engine Management and Tuning
May 29, 2012 10:43 PM
ArmaanOG
Apr 8, 2009 03:16 AM
