Shift rod Spring Pin
I got a 95 civic and i can't get the pin out of the shift rod, so that i can get the engine/tranny out. Got any ideas. I have been pounding on it with a screwdriver and hammer and that is not working to well. Thanks for any help.
[Modified by 95c1v1cs1, 5:10 PM 5/4/2002]
use a 10mm bolt or a flat head punch of the same diameter. a screwdriver will not work because as you hammer it just expands the pin. also you can put some liquid wrench to help ease it out.
once you find the right size pin to pound it out with you will be all set.
give yourself plenty of room also, you need to swing that hammer nice and hard to get that b*tch pin out. I hated removing that thing... good luck
Thanks Guys, i did what you said and it finally came out. I just needed something that size. thanks Alot.
[Modified by 95c1v1cs1, 12:19 AM 5/5/2002]
[Modified by 95c1v1cs1, 12:20 AM 5/5/2002]
hollot1p
Jul 29, 2006 02:08 PM
