need info on b16 pistons and rods
Old Oct 16, 2006 | 07:52 PM
kidrolla's Avatar
Default need info on b16 pistons and rods
ok heres the deal.i want some 11 or 12 compression pistons stock bore and rods.which by the way is b16 bore 81 mm ????im going to be runing a 100 shot on it.were can i order some and if you have links that would be good.also what bearings do i need for the crank. i have a b16a1 obdo in my ef hb.any info will help.also need to know were i can get some head work done.
Old Oct 16, 2006 | 08:21 PM
X291J's Avatar
Default Re: need info on b16 pistons and rods (kidrolla)
Stock b16 bore is 81mm. If your going to be running a 11-12 to one compression with a 100 shot i would be worried about detonation and also your rods. So you should really add tuning to your list. Honda sells bearings, they come in diffrent sizes(colors) so you can see which sizes you need after you plastigauge your crank (its in your helms, dont have one? why not?).
Theres also lots of companys out there that offer head work. Here one that i like http://theoldone.com/
Good luck
Old Oct 19, 2006 | 06:30 AM
kidrolla's Avatar
Default Re: need info on b16 pistons and rods (X291J)
bump for more help
GT500FTW
Jul 29, 2012 05:35 PM
integrawow
Nov 12, 2010 06:23 PM
wingsEK
May 25, 2010 04:38 PM
Aquafina
Jan 13, 2005 07:19 PM
sporkcrx
Aug 12, 2004 10:12 PM
