Suspension Techniques rear sway bar pic????
Old May 4, 2002 | 06:25 AM
Tbone's Avatar
Default Suspension Techniques rear sway bar pic????
I need a pic of the endlink setup installed. I put mine in last night and I think I goofed, the geometry doesnt look right. Thanks
Old May 4, 2002 | 06:29 AM
JDM_DOHC_SiR's Avatar
New User
Default Re: Suspension Techniques rear sway bar pic???? (Tbone)
Sorry bro this is the only pic that I could find on the board
Old May 4, 2002 | 07:13 AM
Tbone's Avatar
Default Re: Suspension Techniques rear sway bar pic???? (JDM_DOHC_SiR)
Hmm, wonder if I have the correct bar, mine comes real close to the strut. But I still need a pic of the other side with the end links
Old May 4, 2002 | 09:42 PM
keithv's Avatar
bump for tbone. i want to see the pic, too, since i helped him out when we ran into this "problem".
Old May 4, 2002 | 10:12 PM
Overkll's Avatar
Default Re: Suspension Techniques rear sway bar pic???? (breaka_1_9)
Try hybrid.honda-perf. I saw picks of the sway bar when JOE-R was installing it. Try the archives. I'll see if I can find it tonight. Later, Overkll
4th Gen is in here http://hybrid2.honda-perf.org/fulllist.html HTH, I didn't look through, but ST bar pictures should be in there.
[Modified by Overkll, 2:15 AM 5/5/2002]
Old May 5, 2002 | 06:42 AM
Lsos's Avatar
I never got mine to work properly, and actually wrecked my suspension when the endlinks broke and I understeered into a curb.
I think the design might be wrong or something. I even took the car to a Suspension Techniques install shop and the result was the same.
By the way, my car was not lowered. I think the bar might have been designed for a lowered car. Anybody have a non-lowered car with Suspenison Techniques sway bars?
Old May 5, 2002 | 07:01 PM
Driven's Avatar
Default Re: Suspension Techniques rear sway bar pic???? (Lsos)
here's how my swaybar is hooked up:
Right side, facing towards right side wheel. If i move the bottom half of the endlink to the lower hole, it would stiffen up the rear-end, causing more off-throttle oversteer. Also notice the amount the endlinks are threaded. This is another part of the adjustability (although slight) of the swaybar.
How it SHOULD be bolted together. This is facing UP towards the car. IE, I was laying on the ground taking the picture. Please notice the spacers between the endlinks.
Old May 5, 2002 | 08:16 PM
manveer's Avatar
Default Re: Suspension Techniques rear sway bar pic???? (Driven)
Yep...mine looks the same as Driven's (just cleaner ).
Old Jan 31, 2003 | 08:54 AM
spun Vtec's Avatar
Default Re: Suspension Techniques rear sway bar pic???? (manveer)
no pic's in this thread i used search can i get a pic?
Old Jan 31, 2003 | 09:20 AM
upstatecrx's Avatar
Default Re: Suspension Techniques rear sway bar pic???? (4gsicivichatch)
can't pix to work right now
[Modified by upstatecrx, 1:22 PM 1/31/2003]
Old Jan 31, 2003 | 09:52 AM
New User
Default Re: Suspension Techniques rear sway bar pic???? (upstatecrx)
Sorry for the Old pic' of the sway bar... I'll have to look for a new one
Old Jun 26, 2005 | 01:36 PM
4potnick's Avatar
help!
Old Jun 26, 2005 | 04:23 PM
onePOINTsix's Avatar
Default Re: Suspension Techniques rear sway bar pic???? (4potnick)
heres a pic...it's kinda hard to see anything tho:
Old Jun 26, 2005 | 04:32 PM
Lo-Buck EF's Avatar
Default Re: Suspension Techniques rear sway bar pic???? (onePOINTsix)
https://honda-tech.com/zerothread?id=1186941
https://honda-tech.com/zerothread?id=766136
those should help....
Nsane1
Dec 27, 2005 05:10 PM
ORcivicsi
Suspension & Brakes
May 17, 2005 06:21 AM
Lil Corb
Apr 15, 2005 08:44 AM
HatchBox
Jun 30, 2004 08:13 PM
Casual Gcode1
Feb 10, 2003 10:12 AM
