B18A1 EG Swap
Old Oct 16, 2006 | 04:00 PM
Spoolind16's Avatar
Default B18A1 EG Swap
Ok. I searched and could not find a definate answer for what exactly I'd need for the swap. I know I'll need ecu, axles an throttle cable however what about the motor mounts?
I plan on using an OBDI b18a1 out of a 92 integra with a b series hydro tranny to swap into my 95 civic 4dr. What motor mounts will I need or what can I use? I've seen on the net that you can use the stock civic mounts with a 94+ rear bracket but I heard the engine sits crocked to one side putting unessessary bind on the engine. Also is the b18a1 drivers side engine mount the same as the b18b1 or can I use the d16z6 stock engine mount on the b18a1? Is this true? Some help please I'm going nuts of over engine mounts
Thanks
Alex Z
Modified by Spoolind16 at 5:22 PM 10/16/2006
Old Oct 16, 2006 | 04:58 PM
Spoolind16's Avatar
Default Re: B18A1 EG Swap (Spoolind16)
Need some help here kinda annoyed.
Old Jul 19, 2007 | 03:37 PM
averyvm's Avatar
how come no one helped ttthis guy?
Im doing the same swap
Old Jul 20, 2007 | 08:27 AM
averyvm's Avatar
Default Re: B18A1 EG Swap (averyvm)
no assistttance dang
Old Jul 22, 2007 | 02:21 PM
Rxmig7's Avatar
I have that swap done....do the search and miracles will happen!
(blown b18a1, looking for b18c1 to replace)
Civic 974
K Series
Sep 8, 2019 05:03 AM
anzh86
Jul 23, 2010 09:20 PM
Spoolind16
Oct 18, 2006 08:31 PM
d15b
Jul 28, 2004 06:41 PM
LshatchTurbo
Oct 18, 2001 04:21 PM
