1st turbo build - please check out and few noob ?
Old Oct 16, 2006 | 01:30 AM
Wheelman-CZ's Avatar
Default 1st turbo build - please check out and few noob ?
I am going to bulid first turbo setup for my friend. I am from Czech (central Europe) and its hard to find somebody for help or for tune.
The Engine will be D16Z5 (OBD0 EDM DOHC Non-VTEC) it is very close to ZC1.
Here is the setup:
HF Manifold (just for start, some better will come later)
Garrette T25 (just for start, T3 later)
unknown FMIC 27,5x8,5x2,5 (2,5 inlet/outlet)
Vitara Pistons from fjt with new rings
TunerToys H-Beam Forged rods
Stealthmode Performance oil line kit
450cc DSM Black Top Injectors
ACL Race Main and Rod Bearing - 0,25 over
Custom 2,5 Charge Piping
BOV by Bidrin (Czech made, but good )
Metal Head gasket.
3 BAR MAP - not sure if I need it
I want to tune it via Turboedit, with wideband O2 and EGT
Is there something wrong in this setup or semething missing?
I have also some stupid noob questions:
1) Which wideband O2 use? I want to datalog, but if I use a turboedit there is a dataloggin so I dont need to use for example LM-1 which have datalogging, I ca use just LC-1?? Is this right?
2) Do I need to use a different MAP senzor? I want to boost about 10 PSI at this time but later we want to try more with a diferent turbo.
3) If I am using RTP with PGMFI Emulator, I just need to have a soketed PM7 ECU + Emulator + some cable + program (Turboedit) and thats all? When I done some map, I can burn it on chip or still use an laptop?
4) How can I check knocking on my engine?
Thats all for this time :-)
Sorry about my stupid questions and sorry about my english
Old Oct 16, 2006 | 08:51 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: 1st turbo build - please check out and few noob ? (Wheelman-CZ)
answers to your easier questions...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wheelman-CZ &raquo;</TD></TR><TR><TD CLASS="quote">HF Manifold (just for start, some better will come later)
Garrette T25 (just for start, T3 later)</TD></TR></TABLE>
dont forget an adapter plate...
1) Which wideband O2 use? I want to datalog, but if I use a turboedit there is a dataloggin so I dont need to use for example LM-1 which have datalogging, I ca use just LC-1?? Is this right?</TD></TR></TABLE>
an lc-1 will work fine for you...its what i use.
2) Do I need to use a different MAP senzor? I want to boost about 10 PSI at this time but later we want to try more with a diferent turbo.</TD></TR></TABLE>
with as many changes as you are making at one time, i would start out with the stock map and ~8psi to get everything running right. then change to a different map if you want to get a different turbo and run higher boost. (just a suggestion)
3) If I am using RTP with PGMFI Emulator, I just need to have a soketed PM7 ECU + Emulator + some cable + program (Turboedit) and thats all? When I done some map, I can burn it on chip or still use an laptop? </TD></TR></TABLE>
the emulator goes in place of the chip...when you have everything tuned, yes, you can take out the emulator and burn a chip...or leave the emulator.
hopefully there is no misinformation in there
Old Oct 19, 2006 | 11:48 PM
Default Re: 1st turbo build - please check out and few noob ? (fastcrxsi90)
Thanks for your answer!
Nobody else???
Old Oct 20, 2006 | 02:32 PM
Laserjock's Avatar
Have you've seen the FAQ at the very beginning of the section:
https://honda-tech.com/zerothread/1024174
Old Oct 20, 2006 | 06:57 PM
SiR99's Avatar
if your going to build the motor dont go with parts you are going to upgrade later like the turbo and the manifold, because everytime you change something you have to retune the car, and dyno time is pretty expensive. Also for a built motor you should be aiming pretty high for our whp numbers so go with good parts. If you have never tuned a car before, DONT tune it yourself, your will most likely mess up the tune and ruin your motor.
Astronaughty
Dec 9, 2014 01:39 PM
nihad
24
Jan 22, 2007 05:08 PM
k9n
May 8, 2004 08:40 AM
91hondacrx
Mar 19, 2003 06:55 AM
Timmayeg
Feb 15, 2003 08:39 AM
