ne body have clutch problems?!???
Old Oct 15, 2006 | 08:01 PM
ntegra2ner's Avatar
Default ne body have clutch problems?!???
today my clutch went out on me or whatever...
i got an 01 itr and ive never had problems with it, and i've had it for a year.
yesterday i got in my car to go driving and when i pushed the clutch in to start the car..it was like there was barely anything there, maybe an inch of clutch...but it was fine. later that day it went back to normal and was normal strenght and everything....but later that night it went back to the barely ne clutch thing....
all of a sudden this morning i get in my car to leave the house, and the same thing...barely any clutch there, except worse this time..i cant even take it out of gear so i can reverse outta my driveway....
i had the clutch in all the way(all 1 inch of it), and im like pulling hard and it still wont come out, so i figured my clutch was shot.....
i need help...lol
Old Oct 15, 2006 | 09:33 PM
RagingAngel's Avatar
Default Re: ne body have clutch problems?!??? (ntegra2ner)
check for fluid/leaks from the master cylinder and slave.
open up the grey cap next to the bigger grey cap (which is for brake fluid)
if that smaller reservoir is empty...fill it up and bleed the sytem and you should have clutch again.... if it's full.... time to pull the transmission to see what's up.
Old Oct 15, 2006 | 10:19 PM
type_eg_r's Avatar
this happened to my friend today. just about to put up a post asking about it. what a coincidence.
Old Oct 16, 2006 | 10:35 AM
dcash13's Avatar
as already said above check to see what your fluid level is.. if its low it just may be slave or master cylinder prolem. pull the boot back on the slave and if there is any fluid in there or it looks dirty then that will tell you right away its your problem.. the same thing happened to me in a h22 teg and the clutch was fine one day and the next it dropped straight to the floor.. and it was only a $25 peice so check that and the master before you start thinking of a major clutch problem..
vtec69
20
May 4, 2005 05:48 PM
OSG 97 ITR
Apr 17, 2004 10:11 AM
range
Dec 1, 2003 02:01 AM
2ksi
Aug 12, 2003 04:45 PM
Powered by Honda
Apr 11, 2002 07:50 PM
