having a problem refilling coolant after swap....thaught i knew how but...
Old Oct 15, 2006 | 05:22 PM
Sleepy_Red_hatch's Avatar
Default having a problem refilling coolant after swap....thaught i knew how but...
okay so i thaught that to fill up the coolant after a swap from dry, i had to fill up the rad, then run the motor without the rad cap on, and as the coolant went down, to keep topping it off....i must be wrong because the level doesnt go down, even when it reaches operating temp....what have i done wrong?
i assume that there is air in the lower rad hose not allowing it to go up to the coolant tube and in terms, the water pump....maybe?
the T-stat MAY not be opening but its brand new so im not sure that its this, but it has NOT been tested
at operating temp, the coolant lines that go to the heater core, intake manifold and upper rad tank are hot, lower rad hose is cold
im ASSUMING (from my gut) that its the first thing, but im not sure, alas, that is why im asking, let me know what you guys think.
thanks,
SRH
Old Oct 15, 2006 | 05:38 PM
Eran's Avatar
HT White Ops
I always put a rag on top of the tank, and hold it down while i pump the hose with my hand.
Old Oct 15, 2006 | 05:41 PM
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">I always put a rag on top of the tank, and hold it down while i pump the hose with my hand.</TD></TR></TABLE>
overflow tank? or did you mean rad?
Old Oct 15, 2006 | 05:43 PM
Eran's Avatar
HT White Ops
Default Re: (Sleepy_Red_hatch)
I pour coolant into my radiator until full. Then I like quad-fold a rag, and put it over the top, and hold my hand down. Then I pump the hose that goes from the top of the tank to the block. Burp it back into the motor, essentially.
Old Oct 15, 2006 | 05:46 PM
Default Re: (Eran)
damn, how many times do you have to refill?
Old Oct 15, 2006 | 05:48 PM
UNKNOWN_MEMBER's Avatar
Default Re: having a problem refilling coolant after swap....thaught i knew how but... (Sleepy_Red_hatch)
don't forget to turn your heater on.
Old Oct 15, 2006 | 05:49 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">damn, how many times do you have to refill?</TD></TR></TABLE>
You basically have to do this till it recycles and can flow through on it's own. After that, it's just filling it while running.
Old Oct 15, 2006 | 05:52 PM
Syndacate's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">You basically have to do this till it recycles and can flow through on it's own. After that, it's just filling it while running.</TD></TR></TABLE>
Old Oct 15, 2006 | 05:58 PM
Default Re: having a problem refilling coolant after swap....thaught i knew how but... (UNKNOWN_MEMBER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">don't forget to turn your heater on.</TD></TR></TABLE>
forgot to list it, but i did it, but thanks for the contribution because someone could have easily forgotten this.
okay, will do, in the morning, im running open top-part-of-header WAY too loud!
Old Oct 15, 2006 | 06:05 PM
SkoundrelUSA's Avatar
cute little bastard
Well, if you're reaching normal operating temperature, it should be fine. Mine didn't go down that much when I added coolant after a swap.
Old Oct 15, 2006 | 08:38 PM
Default Re: having a problem refilling coolant after swap....thaught i knew how but... (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">Well, if you're reaching normal operating temperature, it should be fine. Mine didn't go down that much when I added coolant after a swap.</TD></TR></TABLE>
but the bottom rad hose didnt get hot, and the fan didnt turn on
BadassEFdriver
Jun 20, 2011 06:12 PM
snowblind7x
Feb 21, 2007 08:58 PM
DRKSol
Jun 6, 2005 04:51 AM
Chillinit
Jun 9, 2004 08:16 AM
tFUnK
Jan 2, 2003 12:56 AM
