problems with parts car
Old Oct 15, 2006 | 04:26 PM
crazykamper's Avatar
Default problems with parts car
just to let you know before had, this car was VERY RiCEY, 88 hf with d16a6
parts car run, but VERY VERY lean, i started it up, and i noticed oil shoot out back. ps, *HAD* dual exhaust, previous owner just covered up the other end.... lol!
i checked the engine code and it blinked 20 times in 2per sec interval. i looked at the spark plugs and they were VERY black, then enine obviously is running bad....
some more stuff i have questions on are the sway bar in back, dont know if its custom or what, but does not look like it should be there at all. lol. its yellow.... i have a stock 88si and it dont look anything like that setup....
alot of other problems as well, just some of the first few.....
Old Oct 15, 2006 | 04:36 PM
Suck my DX's Avatar
Default Re: problems with parts car (crazykamper)
whats the question?
your running very very lean, but your plugs are very black?
when you run lean the spark plugs will turn white
Old Oct 15, 2006 | 05:07 PM
Uptowneddiebrown's Avatar
Default Re: problems with parts car (Suck my DX)
The car could be running lean and have bad rings with the black plugs caused by oil burning.
Old Oct 15, 2006 | 05:23 PM
hybrid1990crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">whats the question?
plugs also turn white from burning oil.
Old Oct 15, 2006 | 05:27 PM
i meant the car is running rich, oil rich, my bad. its got lots of oil in the plugs, very black plugs, what could the prob be?????
Old Oct 15, 2006 | 05:29 PM
4dOoR-Ex's Avatar
Old Oct 15, 2006 | 05:31 PM
Default Re: (crazykamper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazykamper &raquo;</TD></TR><TR><TD CLASS="quote">i meant the car is running rich, oil rich, my bad. its got lots of oil in the plugs, very black plugs, what could the prob be????? </TD></TR></TABLE>
oil is getting past the rings or valve seals.
Old Oct 15, 2006 | 07:37 PM
the timing belt did come off the other day, and sopposedly mechanic before i bought it fixed it. maybe the valve seals got messed up when timing came off??? i have my daily driver crx si with the tranny messed up, thats why i mainly picked up this rice, was cause tranny was nicely built, supposedly engine too.. it was dirt cheap so w.e.
could i just take the head off my dd and put in on the parts car engine?? think it would be fine?? or should i just go ahead and rebuild one eninge, make 1 nice stock engine outof 2???
Old Oct 16, 2006 | 02:06 PM
bump, should i just go ahead and rather do a mini me??? which one is easiest to do, least time consuming... thanks!
Old Oct 16, 2006 | 03:08 PM
harmonator84's Avatar
I dont see the picture here????
Old Oct 16, 2006 | 06:26 PM
what pic?? is there sopposed to be one? cause i dont see it either...
SimplyTron
Oct 24, 2007 12:00 PM
M2B4
Jul 30, 2007 09:37 PM
tyflip2
Jul 11, 2004 08:38 PM
arw321
Apr 29, 2002 06:03 AM
B17aTrbo
Oct 29, 2001 04:14 PM
