ECT, IAC, TPS
98 hx is throwing these codes.. the car runs normal when it is up to running temp... its just getting it up to running temp that is the problem.. when i start it in the morning it will just start for a second and die, if i tap the gas it will kinda stay running.. it also has a missfire untill its warmed up and if i hold the throttle wide open it sounds like the timming in way way off and the rpms will not rise but it will just idle really lumpy and backfire
it was running normail a couple of days ago and just started doing this like i said it runs fine when it is at running temp
witch one of these sensors would do this or could it be a combo of all 3 or could 1 of them be bad making the signals for the others off
Spawne32
Jul 9, 2011 05:08 AM
RACEPAK
Oct 15, 2007 03:44 PM
