frankenstein good or bad?
Old May 3, 2002 | 08:01 PM
accord5speed's Avatar
Default frankenstein good or bad?
i just want to know what you guys think about frankenstein motor?
Old May 3, 2002 | 08:02 PM
JdmAcclude's Avatar
Default Re: frankenstein good or bad? (accord5speed)
which combo?
Old May 3, 2002 | 08:03 PM
CmptchAV6's Avatar
Default Re: frankenstein good or bad? (fullmoon)
is there even a way to make a frankenstien motor for an accord that is worht it besides an H23 bottom end with an H22 head?
Old May 3, 2002 | 09:47 PM
Nick M's Avatar
Default Re: frankenstein good or bad? (CmptchAV6)
nope
Old May 3, 2002 | 11:42 PM
After_Burner's Avatar
Default Re: frankenstein good or bad? (HondaSport)
did the H23 have more torque than an H22?? just thought the torque level was about the same??? if so, no point right?
Old May 4, 2002 | 08:29 AM
Nick M's Avatar
Default Re: frankenstein good or bad? (After_Burner)
Their factory torque levels are similiar. All thing considered equal if you were to boost both motors the extra displacement in the h23 would shine through though.
Old May 4, 2002 | 09:25 PM
H23 Power's Avatar
there is a very good point to doing a 2.3L DOHC VTEC engine...
2.3 SI bottom end
2.2 VTEC head
Prelude Type S Pistons.
Everything else stock.
Stock headers, stock intake, stock exhaust
stock cam gears, stock fuel system
In other words, totally stock except S pistons.
[Modified by 01GSR, 12:27 AM 5/5/2002]
Old May 4, 2002 | 09:29 PM
H23 Power's Avatar
Default Re: frankenstein good or bad? (01GSR)
estimating 15% drivetrain loss that puts us at...
219 hp
178 lb-ft
Old May 5, 2002 | 01:29 AM
is that a good thing or bad?
meaning that u mean a 15% loss, but u written 219..thats obviously, better then the H22 itself??
Old May 5, 2002 | 02:30 PM
John's Avatar
New User
normally there's more than a 15% drivetrain loss... a safe bet is 17% IMO.
Old May 5, 2002 | 11:51 PM
H23 Power's Avatar
Default Re: frankenstein good or bad? (DunReit)
yes, so figuring 15% is a conservative estimate
and yes, it obviously makes more power than a stock H22
Old May 5, 2002 | 11:53 PM
oh! ok, just not to knowledgable bout that sorta stuff!!
just that when u said.."loss"..thats what I was referring to!
ok dude!
Old May 5, 2002 | 11:59 PM
H23 Power's Avatar
when you put a car on a dyno, it puts out less power to the wheels than the "crank" hp
this difference is called drivetrain loss...a very low drivetrain loss is 15% for a manual transmission car...which is what I use to figure out the crank hp from a dyno chart. But like said 17 or 18 is more normal, which puts the crank hp even higher than what I stated
Old May 6, 2002 | 08:25 AM
Stew Pidasso's Avatar
01 GSR , what would you estimate the drivetrain loss on an automatic? Just curious.
Old May 6, 2002 | 08:27 AM
Big James's Avatar
New User
Default Re: frankenstein good or bad? (Nitz5785)
About 95%!!!!!
j/k
It is around 20% or so.
Old May 6, 2002 | 08:29 AM
4doorH22's Avatar
2.3 SI bottom end
2.2 VTEC head
Is this from Importreview? Who the hell would build a motor like that and choke it with stock I/H/E. I'd think aftermarket I/H/E should get a 2.3 VTEC with Type S pistons close to 200 WHP.
BrockNB
Aug 15, 2006 06:25 PM
f22accord
May 3, 2005 01:07 PM
mp15_LUDE
Apr 15, 2005 10:47 PM
vinuneuro
May 10, 2004 12:58 AM
as i lay dying
Apr 27, 2004 07:22 PM
