Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
VTEC QUESTION...
Old Oct 15, 2006 | 10:17 AM
NA4sho's Avatar
Default VTEC QUESTION...
does vtec not kick in when engine is not warmed up yet? plus whats the difference between regular vtec and the ivtec? is it just more fuel friendly? thanx guys
Old Oct 15, 2006 | 10:42 AM
SteaveO2's Avatar
Default Re: VTEC QUESTION... (NA4sho)
Umm it should kick in whens it's cold but i wouldn't really know cause it's not good to rev it up that high when it's cold. Just don't touch vtec till the car is at operating temp.
And regular VTEC is just the variable lift where the intake valve rockers switch to a larger lobe. On I-VTEC it still does that but in addition it can retard and advance the intake cam on the fly which further increases torque.
Old Oct 15, 2006 | 10:47 AM
06blaksi's Avatar
Default Re: VTEC QUESTION... (SteaveO2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteaveO2 &raquo;</TD></TR><TR><TD CLASS="quote">Umm it should kick in whens it's cold but i wouldn't really know cause it's not good to rev it up that high when it's cold. Just don't touch vtec till the car is at operating temp.
And regular VTEC is just the variable lift where the intake valve rockers switch to a larger lobe. On I-VTEC it still does that but in addition it can retard and advance the intake cam on the fly which further increases torque.</TD></TR></TABLE>
Correct. Also, VTEC will not kick in if the engine is cold, car is parked or low on oil
Old Oct 15, 2006 | 01:32 PM
06civicsareus's Avatar
the only difference between vtec and ivtec is that ivtec prevents you from hitting vtec when the engine is cold thats it
Old Oct 15, 2006 | 01:38 PM
eL's Avatar
eL
Default Re: (06civicsareus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 06civicsareus &raquo;</TD></TR><TR><TD CLASS="quote">the only difference between vtec and ivtec is that ivtec prevents you from hitting vtec when the engine is cold thats it</TD></TR></TABLE>
I hate to be the one to break the news but you are WAY off.
VTEC from say a B Series engine will not engage [or hit as the ricers say] when the engine is cold just as IVTEC engines won't do it when the engine is cold.
Old Oct 15, 2006 | 01:42 PM
so both dont "engage" (im no ricer, bad choice of vocabulary) when the engine is cold?
Old Oct 15, 2006 | 01:54 PM
eL's Avatar
eL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 06civicsareus &raquo;</TD></TR><TR><TD CLASS="quote">so both dont "engage" (im no ricer, bad choice of vocabulary) when the engine is cold?</TD></TR></TABLE>
Correct.
Old Oct 15, 2006 | 01:59 PM
alright, thanks for clearing that up about the temperature issue, here is a link that will clear up the original poster's issues:
http://asia.vtec.net/article/k20a/index.html
Old Oct 15, 2006 | 02:15 PM
haby red fg2's Avatar
here is the best way to understand vtec https://honda-tech.com/zerothread?id=1689966
Old Oct 15, 2006 | 03:35 PM
SteaveO2's Avatar
Default Re: VTEC QUESTION... (06blaksi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 06blaksi &raquo;</TD></TR><TR><TD CLASS="quote">
Correct. Also, VTEC will not kick in if the engine is cold, car is parked or low on oil</TD></TR></TABLE>
Aight, i wasn't sure on that one. Never tried it, it's not hard to wait like 5 mins for the thing to warm up before u hit vtec. I usually don't go over like 4 grand when it's cold.
Old Oct 15, 2006 | 04:01 PM
Demonis's Avatar
What seperates hondas VTEC from all the other auto makers 'vtec' like processes? Only thing I notice, is when vtec kicks in, its a lot more of a 'kick' than other makes.
Old Oct 15, 2006 | 06:53 PM
John Z's Avatar
wow this is a total hack of a thread..
Vtec is on the intake and exhaust cam on B and Ks..
Vtec is when the cam has 2 lobe profiles.
on a B series Vtec needs
oil pressure(not on JDM motors)
coolant temp(not on hondata from what i hear)
speed sensor
on a K i have NO IDEA
but i would expect speed and oil pressure
now the I has to do with the variable intake cam where it will advance and retard. kinda like the AVCS found on a subaru sti
fuzzysig
Apr 17, 2017 09:34 PM
Hapa88
Apr 22, 2004 09:20 AM
sampsonnight
Apr 17, 2002 01:25 AM
vincent97gsr
Jan 28, 2002 10:55 PM
Type-Rare#1248
Dec 25, 2001 12:17 AM
