would a bad ICM or dizzy parts hrow a CEL?
Old Oct 15, 2006 | 10:01 AM
DVS Luder's Avatar
Default would a bad ICM or dizzy parts hrow a CEL?
would a bad ICM or other bad distributor parts including the coil throw a CEL?
Old Oct 15, 2006 | 06:09 PM
JasonST's Avatar
Default Re: would a bad ICM or dizzy parts hrow a CEL? (DVS Luder)
I don't think so. When my coil went out it didn't throw a code, and from what I hear from ppl when ur ignitor goes out it doesn't throw a code eather. What's the problem ur having I'm sure me or somone else could help.
Old Oct 15, 2006 | 07:05 PM
Jago's Avatar
Default Re: would a bad ICM or dizzy parts hrow a CEL? (JasonST)
after as much as ten seconds of cranking the engine you can get a code 16
ignition output signal. this is usually caused by a bad ignitior not sending a signal to the ecu.
Old Oct 16, 2006 | 01:39 AM
DVS Luder's Avatar
Default Re: would a bad ICM or dizzy parts hrow a CEL? (Jago)
code 16? immah try that tomorrow, cranking it up for as much as 10 seconds.
jasonST, did u notice any signs of your coil going out or did it just die one day?
boostedb20z
Jun 25, 2009 12:11 PM
Car Tweaker
May 14, 2009 05:32 AM
lazyxmofo
Feb 13, 2009 06:43 AM
kuteboi
Jan 29, 2005 09:11 PM
PowerHouse
Nov 12, 2004 04:01 AM
