d16z6 into 92 dx (d15b7) map sensor
im almost finished with my swap but i have a quick question for the map sensor.
my d15b7 map sensor wiring ran from the firewall and connected to the map sensor (mounted by the fuel filter)
on my d16z6 the map sensor is mounted to the throttle body (str 68mm tb) and there is a map sensor connection on the d16z6 wiring harness.
i was wandering which connection i should use? the one that comes from the firewall, or the one on the z6 engine wiring harness?
they have the same color wires, same connection. Also, ill be running the p06 at first, until i can get my p28 if that makes any difference
there is also one wiring harness on the d15b7 that runs from under the distributer up to the passenger side shock tower, however, i cannnot find where that one came from. I dont know the color on these wires, but my d16z6 doesnt have this connection but does have an unused plug down there. i may have to get a picture up to get any help with that one tho.
Modified by 92ehatch at 9:30 AM 10/15/2006
preparing to leave to work on car, dont have a computer there. really quick answer please
use firewall connection or main engine harness connection for MAP sensor on d16z6 running a p06 in 92 dx hatch (originally d15b7) ?
ej1b18c1
97
Feb 21, 2012 07:31 PM
Mikes2000civicsi
Jun 4, 2011 09:02 PM
SOHCEK-Turbo
Oct 16, 2003 09:42 PM
