what is the best cam setup for a b16a
Old May 3, 2002 | 06:49 PM
puffinrice's Avatar
Default what is the best cam setup for a b16a
what is the best cam setup for a b16a i have seen come people using one CTR cam and one ITR cam, which is which and how come you don't use the set. also, would it be better to run both ITR cams with the ITR mani, since they will be basically set up for each other? thanks guys
Old May 3, 2002 | 07:02 PM
714phil's Avatar
Default Re: what is the best cam setup for a b16a (puffinrice)
use the CTR intake cam.. ITR exhaust cam. the itr exhaust cam pretty much has the same exact lift as the ctr one.
Old May 3, 2002 | 07:04 PM
E-AT_me's Avatar
Default Re: what is the best cam setup for a b16a (STD ONEpointSIX)
for what setup are you building? turbo? NA? daily driver? these questions and more must be answered first.
Old May 3, 2002 | 07:07 PM
puffinrice's Avatar
Default Re: what is the best cam setup for a b16a (Rexman)
NA daily driver.
Old May 3, 2002 | 07:26 PM
MrFatBooty's Avatar
skunk2 Stage 1:
civic-si-2000
Sep 2, 2003 07:39 AM
pstreck
Aug 8, 2001 10:36 AM
