Pin removal tool for openings this size?
Old Oct 15, 2006 | 12:44 AM
MidShipCivic's Avatar
Default Pin removal tool for openings this size?
http://www.dodgeintrepid.net/f...40991
Old Oct 15, 2006 | 05:54 AM
beepy's Avatar
Default Re: Pin removal tool for openings this size? (MidShipCivic)
Broken link.
Old Oct 15, 2006 | 08:03 AM
siblues's Avatar
Default Re: Pin removal tool for openings this size? (beepy)
The link works for me?I am of no use on this topic?
Old Oct 15, 2006 | 09:56 AM
Work fine when I clicked it?
They arent weahter pack connectors there much smaller there common honda ecu style pins ( dont know the style of this pin) .
Old Oct 15, 2006 | 02:22 PM
C_H_A_D's Avatar
Default Re: (MidShipCivic)
The guy who made the write up sure could use a macro shot lesson.
Old Oct 15, 2006 | 07:13 PM
CarbonizedDX's Avatar
Default Re: (NINJASWORD)
It's just a tiny flat head screw driver. Most tool shops should have sets of screw drivers that should have one that small or it may be singlely but they do exsist.
Old Oct 15, 2006 | 07:20 PM
Default Re: (CarbonizedDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarbonizedDX &raquo;</TD></TR><TR><TD CLASS="quote">It's just a tiny flat head screw driver. Most tool shops should have sets of screw drivers that should have one that small or it may be singlely but they do exsist.</TD></TR></TABLE>
DUH
May be small driver but there not . '' pin removal tools''
Old Oct 15, 2006 | 10:03 PM
The only "pin removal tools" I've seen/used are Molex pin removers...... Beyond that it's screw drivers and exacto knives.
I've done brake jobs with tools that weren't "brake tools", does that mean they didn't work? no, just ment the user had to be a little smarter to yeild the same effect. Let me tell ya when in the middle of a drum shoe change you don't wanna run to the store for one or two tools when the same job can be done with different tools.
Old Oct 15, 2006 | 10:07 PM
^ useless.
http://www.p-r-s.com/catalog.htm
Old Oct 16, 2006 | 02:35 PM
Slow00si's Avatar
snap-on and matco both make pin removal tool kits for all different oem pins but i usually use my straight matco pick. and it usually fits in all oem plugs easily because the pin tools arent worth the money too me but like everybody else said the tiny flatheads or a small straight pick usually work.
Old Oct 16, 2006 | 02:48 PM
''Dee dee dee'' mind of mencia up in here.
NO screw drivers, I do not want that.
Found another.
http://www.aircraftspruce.com/...t.php
Old Oct 16, 2006 | 03:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">
So you make a post asking for info on tools that you already went ahead and found on your own. Thusly you've made this post worthless and your comments/replies useless.
Old Oct 16, 2006 | 04:49 PM
Read the topic title, says '' PIN REMOVAL tool'' not use a screwdriver as one. I already took the ECU pins out without one of these extraction tools.
I'm looking for a specific your too busy saying use a screwdriver.
Sure I'll ask the question and keep looking it only makes sense.
Stay away
Old Oct 16, 2006 | 05:32 PM
Next time use GOOGLE
BringIT
Aug 12, 2007 09:31 PM
DFW
12
Jan 15, 2007 12:39 AM
-Gary-
28
Apr 4, 2006 06:15 AM
iwhichisme
Sep 6, 2004 05:22 PM
AznJohn33
Jan 10, 2004 08:58 AM
