Question regarding Knock Sensor Obd0-Obd1 jumper to p13 H22A engine
Old Oct 14, 2006 | 08:03 PM
E-Speed
Guest
Posts: n/a
Default Question regarding Knock Sensor Obd0-Obd1 jumper to p13 H22A engine
I am using a p28 made harness in my crx needed to switch out ecu's for the time being to p13 h22a ecu...my question is regarding the knock sensor 1 wire hook up goes to pin out D3, I was using a p28 h22 ecu but need to swap my p13 h22 ecu back in for the moment...can I splice in the 1 wire knock into the D3 pin out on the jumper side, before it hits into the ecu plugs?
I am cautious of firing it up again without a guranteed answer...problem was tried running the p13 without knock seemed to not run completely right? could be on safe mode??? cuz of no knock at the time?
the knock sensor plug is similar to a common 2 wire honda plug...instead of guessing which wire to pull our of the knock can I splice the 2 wire plug...off the plug into 1 wire then into D3? Does the knock have 2 prongs or 1 also?
Modified by E-Speed at 9:25 PM 10/14/2006
jdmdseries
Nov 16, 2007 03:46 PM
sir2sol
May 12, 2007 05:32 AM
deucedeuceEK9
Feb 2, 2006 12:13 PM
FleXingMyEK
Dec 28, 2002 07:43 AM
