finished my swap, 3 codes
Old Oct 14, 2006 | 03:42 PM
Sleepy_Red_hatch's Avatar
Default finished my swap, 3 codes
CAR: 1992 VX
MOTOR: JDM D15B Vtec
codes thrown:
14 IACV
20 ELD (Electric Load Detector)
22 Vtec Oil Pressure Switch
what i need:
CODE 14:
-is it possible that the valve is simply clogged? how do i fix this?
CODE 20:
-what the hell is this? how do i fix this?
CODE 22:
-i dont have an oil pressure switch there is a way to disable it completely, but i forget how...
thanks,
SRH
Old Oct 14, 2006 | 04:06 PM
Eran's Avatar
HT White Ops
Code 14:
Take off your IACV, and spray the expletive out of it with carb/brake cleaner.
Code 20:
Unbolt your underhood fuse box, and make sure the ELD conector (brown) is making good contact. Mabe clean with some break clean and put on some dielectric grease.
Code 22:
Yes you do have a VTEC Oil Pressure Switch. It's your solenoid. Clean out the screen.
Old Oct 14, 2006 | 04:10 PM
sicones's Avatar
Default Re: (Eran)
if your alternator is not connected properly it will cause code 20
Old Oct 14, 2006 | 04:11 PM
Eran's Avatar
HT White Ops
Just a good thing to know:
Code 20's are hardly EVER caused by an acutal faulty ELD. It's generally a secondary symptom. Alternator, poor/no connection to ECU, etc.
Old Oct 14, 2006 | 04:16 PM
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Just a good thing to know:
Code 20's are hardly EVER caused by an acutal faulty ELD. It's generally a secondary symptom. Alternator, poor/no connection to ECU, etc.</TD></TR></TABLE>
maybe you don't understand....i have a BOLT where the pressure switch goes but i'll check those thigns out, thanks!
Old Oct 14, 2006 | 04:20 PM
Eran's Avatar
HT White Ops
Default Re: (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">maybe you don't understand....i have a BOLT where the pressure switch goes but i'll check those thigns out, thanks!</TD></TR></TABLE>
LOL, well that's why. Your ECU isn't getting a pressure switch signal, so it throws a low voltage code. You kind of fuckered yourself there.
Old Oct 14, 2006 | 04:22 PM
Default Re: (Eran)
LOL, well that's why. Your ECU isn't getting a pressure switch signal, so it throws a low voltage code. You kind of fuckered yourself there.</TD></TR></TABLE>
the motor came like that...i heard there was a way to disable it altogether by jumping it to another wire that gives the voltage the OPS would have...
Old Oct 14, 2006 | 04:23 PM
Eran's Avatar
HT White Ops
Why don't you just buy a new pressure switch? I imagine it's not good for the motor to bypass a switch that controls which stage your cam profile is in.
Old Oct 14, 2006 | 04:27 PM
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Why don't you just buy a new pressure switch? I imagine it's not good for the motor to bypass a switch that controls which stage your cam profile is in.</TD></TR></TABLE>
well the pressure switch is simply a "just incase" thing, but yeah i'll cee if i cant get another...im poor, this swap came out of the blue and now i have 150$ or so to last me 2 months, i work and all, but it must ALL go towards paying a visa bill
Old Oct 15, 2006 | 04:53 PM
UPDATE!!
okay i was using the wrong plug for the IACV code 14 is a goner....
code 20 is what im trying to figure out, ALL grounds are tight, alt is tight, starter is tight, battery connections are tight and clean....
code 22: well i need to stop being a cheap-*** and buy a VOPS
Old Oct 15, 2006 | 09:21 PM
UPDATE!!
i stole the oil pressure switch off a VX motor i had laying around, tomorrow morning, i will see if that will resolve my CEL altogether. (if not, i'm still at a loss for code 20)
Old Oct 16, 2006 | 07:42 AM
update!
installed the VOPS, NO MORE CODES! this swap is OFFICIALLY a success, (except for the cooling issue)
n1_egsex
Sep 1, 2007 03:00 PM
vtec-civic1089
Honda Civic (2001 - 2005)
Apr 12, 2007 02:46 AM
endlesswinterco
Jan 10, 2004 01:26 PM
spoonfedGSR
Sep 26, 2003 02:31 PM
Fuster_Cluck
May 15, 2003 10:05 AM
